Originally posted by Gen2RacerX
How do i change the steering wheel on my gen 2?
Theres a few screws under the center section (horn) of the steering wheel.
After you remove the center section you'll see a big nut in the middle. You need to remove this nut and use a steering wheel puller.
You can rent a steering wheel puller from a autoparts store. I know Autozone rents them out.
What parts will i need to install the steering wheel?
You need a hub / adapter for the wheel. It allows you to bolt up a aftermarket steering wheel to the stock steering column.
Also when i remove my old steering wheel, will i lose my horn? or can i hook up my horn to the two buttons on my new wheel?
The horn will still function with the new steering wheel as long as you hook it up.
