Check engine light on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-08-2007, 12:02 PM   #1 (permalink)
mk2-1jz's Avatar
View mk2-1jz's Photo Gallery
2nd Generation Check engine light on
Hey guys, I've got a problem. My check engine light is on. It came on after I cleaned and gapped my spark plugs (.043") and checked some vacum lines (which were all ok as far as i could tell). When i was done i started the car then let it idle for a while, when it was warm i took it out and pushed the RPM up to about 4500 before i let it shift, then i noticed the check engine light was on. What could have happened? The car runs fine, starts fine, idles ok (dips ever so slightly, i think the injectors need to be cleaned) and has its normal amount of power. I thought maybe i pinched a vacum line or something when i was checking them and it would trigger the light. So i tried unplugging the battery to reset the ecu and dump the codes. I started it back up and within 2 seconds the light came back on.
I'm stumped and I had a look at the camry manuals, there is no troubleshooting problems section. What could have happened? I've had this car for over a year now and this is the first time the light has come on
Build Thread: http://forums.celicasupra.com/showthread.php?t=53215
~ Jamie - 1985 Supra - 1988 Camry
~ Supra, Its a Religion
mk2-1jz is offline   Reply With Quote
Old 10-08-2007, 12:42 PM   #2 (permalink)
mk2-1jz's Avatar
2nd Generation
dont ask me, It fixed itself....
Old 10-08-2007, 02:01 PM   #3 (permalink)
View monito's Photo Gallery
It didn't fix itself. You need to pull the diagnostic codes [aka ODB codes].
To do that you need to jump terminals E1 and T, turn the ignition switch to the on position [w/out starting the engine] and read the CEL blink patterns.
If it disappeared, chances are you have a code 71. I have a code 71 and it comes on and off every so often.
monito is offline   Reply With Quote
Old 10-08-2007, 02:21 PM   #4 (permalink)
mk2-1jz's Avatar
2nd Generation
what does code 71 signify
Old 10-08-2007, 02:31 PM   #5 (permalink)
Code 71 = Problems with the EGR system. Most of the time the problem is fixed by just cleaning out the EGR valve. Do a search on the GEN 1/GeN2 forum for Code 71 and/or EGR.
If you're Gen2 is a 2vz-fe, i can help you w/ the removal process, otherwise there's plenty of help for the 3s-fe.
Old 10-08-2007, 09:07 PM   #6 (permalink)
mk2-1jz's Avatar
2nd Generation
3s-fe, thanks a lot Ill look into it
Corolla 2002 P1349 trouble code? check engine light. g.b. Archived Corolla threads 6 10-01-2009 01:52 AM
check engine light Islandtrix 1st Generation (2003-2008) 17 03-05-2009 01:02 AM
Is the 07 camry tranny a POS ?? Eyekutr 5th & 6th Generation (2002-2006 & 2007-2011) 97 01-22-2007 11:20 AM
Check Engine Light (again) t4x4_offroad Camry & Solara Lounge 5 10-19-2006 11:52 AM
2005 Matrix Check Engine Light? : OBDII SCanner Buying Tips? Matreks 1st Generation (2003-2008) 13 07-05-2005 11:25 PM
