Pod filter installed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-09-2007, 07:54 AM   #1 (permalink)
Camgod
Carlman(90 CS)'s Avatar
View Carlman(90 CS)'s Photo Gallery
2nd Generation Pod filter installed
hi all,
finally got a picture of my instlalled pod filter. for 100$ i got my self a better sounding stock exaust system, more high end power, better throttle response and so on. heres a pic
Long Live 2nd Gen!!
Carlman(90 CS) is offline   Reply With Quote
Old 10-09-2007, 02:39 PM   #2 (permalink)
89 2wd's Avatar
View 89 2wd's Photo Gallery
Looks good, too bad the filter doesnt fit in the fender for that extra coldness What did you do in terms of the exhaust? I need to replace my pipe soon b/c it's developing leaks.
I was going to do something similar with the intake, but don't have the motivation until I can find a way to replace that restrictive z-tube between the AFM and the TB. I have only removed the sliencer in the fender so far.
I might do some 3" Home depot tubing like on my truck:
'01 Tundra SR5 2UZ-FE 2WD
'89 X-tra cab 22RE 2WD
'91 SR5 4Runner 3VZE 4WD (sold)
'88 Camry LE 3SFE (sold)
89 2wd is offline   Reply With Quote
Old 12-19-2007, 12:16 AM   #3 (permalink)
View brohawk's Photo Gallery
nice job man im hooking my car up with one on my 2 weeks off as well as a few other lil mods ill put pics up here wen im done
brohawk is offline   Reply With Quote
Old 12-19-2007, 03:35 AM   #4 (permalink)
Camgod
Australia
im still amazed at the power it opened up! At 4k rpm it sounds sweeeet almost like a wrx and this is on stock exaust all the way through.
Long Live 2nd Gen!!
Old 12-19-2007, 03:49 AM   #5 (permalink)
nice mine has a hole in the center mufler so im going to hack it off there fit either a hot dog or another muffler 2.5" pipe to the back were im going to mount a y piece with 2 small cannons so that should open up the sound a lil
Old 12-19-2007, 11:42 AM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
hey carlman, get a 3sge manifold and downpipe off a celica and put onto it
Old 12-19-2007, 07:54 PM   #7 (permalink)
NYR
View IvanHoe's Photo Gallery
Originally Posted by Carlman(90 CS) View Post
hi all,
.....but your sucking in hot air.....kinda defeats the purpose
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 12-19-2007, 09:49 PM   #8 (permalink)
View MARIO2007's Photo Gallery
Wait you paid a hundred bucks for that filter?
MARIO2007 is offline   Reply With Quote
Old 12-19-2007, 10:18 PM   #9 (permalink)
Camgod
Australia
If you want the best you have to fork out the cash
Thats for the Filter and adapter.
Long Live 2nd Gen!!
Old 12-20-2007, 01:12 AM   #10 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
100$ AUS isn't the same as 100$ in USA
Old 12-20-2007, 01:36 AM   #11 (permalink)
Camgod
Australia
yea i know that or were you talking to MARIO2007?
Long Live 2nd Gen!!
Old 12-29-2007, 09:32 PM   #12 (permalink)
Toyota. Possibilities.
PaulyJay's Avatar
View PaulyJay's Photo Gallery
hey, just joined today. love the work on your pod, got a q though......... how are you securing the pod and air flow sensor so it don't move around? i've already got most of the parts i want to do pretty much the same thing, but i'm gonna build an aluminium box to cut engine heat, and cut a hole in the bonnet. before i do it anyone got any suggestions or such?
Gen 2 Camry SW 2.0ltr 5Spd Man '90
PaulyJay is offline   Reply With Quote
Old 12-29-2007, 10:06 PM   #13 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
That's an ambitious plan of yours, PaulyJay. Getting the aluminum housing to seat snugly with the contours of the bonnet/hood when it's latched will be tough. You'll probably need lots of weather-stripping (the foam tape for home windows).
For the opening in the bonnet, go to a scrap yard and try to find functional hood vents for a neat look. My coworker grabbed vents off of an old Turbo Sunbird, but I don't even know if GM sold those Down Under...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 12-29-2007, 10:50 PM   #14 (permalink)
PaulyJay's Avatar
Australia
ah, some constuctive crit! anywho, i already have a bonnet scoop, very low profile...... have done this type of mod before but in a coon (thats aussie for ford falcon). worked well. as far as i know it's still runnin. however i didn't bother so much with the sealing aspect of the first project. this time is quite easy. take a long piece of standard upholsterers foam, (about 4cm x 3cm and bout a metre and a half to 2 metres long) wrap it in glad wrap (this sounds kinda gay but its worth doing to make the next step easier or so i'm told) next you need to get a water proof material, or thin but strong latex, and again wrap the foam. not too tightly though. once this is done use some double sided tape to attach it to the bonnet. abbra kadabra you have a well fitting seal for the top of the air box. obviously rubber grommeting is needed for the top of the box as this covers not only any lazy problems, ie not filing the top of box to clean it up, but means the seal is not cut in to through normal engine vibrations. when it's done i will post a finished pic and some construction pics aswell. there is no reason this mob couldn't be appropriatley applied to other cars too. like a pinto! ha!
Australian 1990 Camry CS Wagon 3S-FE, S51 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-F, 5Spd Man (RIP)
Australian 1990 Corolla SECA Liftback 4A-GZE, 5Spd Man, AWD (currently in build)
Old 12-30-2007, 03:18 AM   #15 (permalink)
Camgod
hi paulyjay welcome to the forum m8, im Ozzie too where u from?
anyway, installing this has helped alot with my cars acceleration but mostly the higher revs around 4k rpm plus. Building an aluminum box would be easy done i helped a m8 do the same thing, what we did is strip out everything from around where the filter used to go and the proceeded to 'mold' the aluminum around the suspension housing and such.
On my car it is attached via two of these soft steel 'plates' that you can usually get around where you get the adapters in super cheap auto or similar. They hook under the hose clamp and bolt using the original screws into the car body.
so u a ford or a holden man (plese tell me ford lol)
Long Live 2nd Gen!!
22re fuel filter mod... ncpaladin Pre-88 Toyota Pickup/Hilux 2 09-25-2007 05:46 AM
4afe pod filter big_fella6699 Archived Corolla threads 2 08-22-2006 12:31 AM
NAPA Gold Oil filter vs Toyota rjs 2nd Generation (2005+) 4 08-15-2006 09:57 PM
Factory oil filter removal - 2.7 4cyl bnacat 2nd Generation (2005+) 5 05-04-2006 04:19 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
