brake light problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2007, 10:52 PM   #1 (permalink)
View dzyd's Photo Gallery
Gen1 brake light problems
88 camry le: my brake lights will not work when the brakes are activated. however, they will flash when i set my car alarm so i know the fuse and bulbs are fine.
also, twice while making a sharp right turn the dash brake light came on for a second.
dzyd is offline   Reply With Quote
Old 10-11-2007, 12:09 AM   #2 (permalink)
View Kingdom934's Photo Gallery
Maybe it could be the switch inside under the dash that doesn't seem to be on when the brakes are pressed?
As for the brake lamp coming on during sharp turns, might want to fill the brake fuild reserve to the 'MAX' line. I remember when I bleeded my brakes, the light was on even when I had just between the 'MIN' and 'MAX' line.
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 10-11-2007, 12:48 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
yes check your brake switch. it's behind the brake pedal.
Old 10-12-2007, 11:44 AM   #4 (permalink)
im assuming i need to remove the dash to get to the switch. i can see it and get one hand barely on it, but thats about it. how much of a hassle is it going to be to remove the dash? i got a quote to fix the switch- $30 for the switch - $95 for labor.... that seems steep to me. i will do it myself if its not too hard, but i have never messed with the dash before. will i be getting in over my head?
edit: i found a switch at auto zone for $15. should i attempt to do this myself? has anyone replaced a switch themselves? how hard is it?
Old 10-12-2007, 12:36 PM   #5 (permalink)
The Gen2 Manuel should be up for downloading. Let me find the links.
http://www.camrymanuals.com/index.ph...=105&topicid=0
That should do the trick
'85 Camry DLX 158K
'87 Cressida 78K
'04 Camry XLE V6 52
Old 10-12-2007, 01:32 PM   #6 (permalink)
Thanks for the link. This will definately help. Looks like I will be busy tomarrow.
Old 10-13-2007, 03:55 PM   #7 (permalink)
View marc780's Photo Gallery
no its not behind the dash...follow the brake pedal lever up under the dash, press it with you hand and you ought to hear it click. To remove the switch connector, press it in the middle and pull it off. Use a wrench to loosen the locknut (13 or 14 mm probably). Then unscrew it. COUNT THE NUMBER OF TURNS. Install the new one the same number of turns then fine adjust so the brake light comes on the right time. It helps to park near a wall or something that will show the brake lights shining. (Sometimes i use a long stick to press the pedal!) Then tighten the locknut.
Old 10-13-2007, 07:57 PM   #8 (permalink)
USA
OK, all is good now. I just had to remove the dash panel underneath the steering wheel, and even that didnt give me much more room to work with. That switch seems nearly impossible to get a wrench on much less turn the wrench. Anyway, it took me a good couple of hours from begining to end, but I finally got it.
I could tell the switch was bad as soon as I saw it. The button was jammed and would not release. It was obvious that was the problem. I hope to never have to do this again. I had to bust some serious contortionist like moves to reach this thing, and I am six foot tall nearly two hundred pounds.
Anyway, final cost was $15 for the switch at AutoZone, a couple hours of my time, and a sore back. Thanks for all the help from everyone. You made the task much easier and a lot cheaper than what it could have been.
brake light on? mfunk49 1st Generation (1995.5–2004) 4 02-04-2007 12:40 PM
Brake Light Problem zootjeff 1st Generation (1995.5–2004) 2 01-21-2007 07:35 AM
What do I have to do to get a left brake light on the trailer when towing??? Ron V 2nd Generation (2005+) 4 10-09-2006 05:50 PM
Stuck brake light heller 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-18-2006 04:12 PM
brake light on dash,, GO AWAY!! alieneyed Celica Forum 13 01-06-2005 01:15 PM
