Ignition switch replacement/starting problems
Hey and good day. Am I daft or does the Toyota Camry manual that is availble for download here at this excellent site not have any instructions on R+R of the ignition switch? I know this has probably been discussed a million times on the board. But when I do a search for ignition switch, or ignition switch replacement or etc. etc. I have found nothing about the actual instructions. In fact I find just a bare mention of maybe the problem is the ignition switch or this or that. So please forgive me if I have just wasted space and did not find what should have easily been found.. I know I could probably wing it. But I have never been in to the column of a toyota camry 1990 LE. I have found through many years that reading a repair manual can save time, money, and accidental breakages of things, so that is why I would really love to have it if available. The manual seems to talk about replacing the other switches in the column but nada for the ignition switch..
My daughters car will not start. I have bench tested the starter. Works perfect. I have checked the Neutral safety switch for continuity as called out for in the manual. It passes. When I turn the key to start I am not getting any voltage to the small lead wire that goes to (st50) on the starter just above the Battery cable connection. I can hear the relays klicking in the fuse box next to the battery. But no juice to the starter..
I notice there is a ignition or a starter relay on the left hand kick panel on drivers side. But the manual as far as I can tell says nothing about what it does. It does not include it in any of the trouble shooting suggestions for Non-start trouble shooting. I know that on the autos apparently the Main engine relay does not affect juice to the starting system on Auto's because the car will start (previously before this problem) without the relay plugged in.
Any help, and advice is very much appreciated. I don't mind replacing the switch if that is what it is. But these other things that seem to be non-discussed in the manual have me scratching my head.
thankyou very much for your time and trouble..
String
