Torque converter noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-15-2007, 11:31 AM   #1 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
If you hear the noise (high pitch whine) that is present only after you shifted out of park or neutral while the drive wheels are stationary it most likely to come from the torque converter. However on the old car this noise may be masked by exhaust rattle, belt squeaks or even sheet metal vibration. This method works on A140e transaxle with electronic control (Not A140L). This test is need to be made only if there is a strong suspicion that noise originates from the torque converter and is not recommended to be used as pre-purchasing inspection of the car. The test is performed as follows:
1. Unplug the connector to the solenoids (to put transmission in MANUAL mode)
2. Modify remote starter switch so it could reach from the battery to the steering wheel
3. Attach one clip to the lock up solenoid terminal (number 3 solenoid or SL solenoid)
4. Connect other clip to the battery positive terminal
5. While sitting on the driver seat
· Start the engine
· Apply the brakes
· Shift to 2 (this will put transmission to the 3rd gear)
· Push the button of the switch. This will apply TC clutch, blocking the converter. The engine will bog down and may die, so hold the button just momentary to hear if noise is going away. (On the car I tested the noise disappeared right away, and rpm fell from 800 to 400, but the engine did not died)
This test will not work at the first gear, because the Lock-Up signal valve hydraulic circuit is blocked by 1-2 shift valve. (Fail safe feature).
Now, there is a bunch of questions:
On the car I tested (88 Camry Wagon 128 kmi), the original TC was replaced with the rebuild one to cure the noise complaint AND the unsatisfactory low stall speed (1400 rpm vs. 2200). The replacement did not make improvements. There were no broken metal chips in the pan and fluid was bright red after 20000 mi. of service. The transmission shifts fine, however the car starts to move from the stand still like “overloaded”. The noise briefly intensifies (screams) then goes away. The transmission input and stator shafts are in the good condition (radial and axial play within the specs) The removedTC had no contamination either!
Based on the diagnostic article by L.Carley, the whining noise is pointing to the TC roller thrust bearings.
I am personally suspecting several reasons for the noise:
  • The TC lock up clutch is not fully releasing (however It applies at 50 mph as confirmed by test light on the solenoid and RPM drop on the tach).
  • The engine (3SFE) thrust bearing is badly worn, transferring the thrust load to the TC bearings (but the drained engine oil was clean)
  • The rebuild TC is bad
  • There is misalignment between engine and transmission.
  • Defects in lock-up relay valve (allows bleeding of lock up pressure, that allows TC clutch to drag )
Have anybody had the same or similar situation?
The used transmission is the last resort solution due to the poor quality of used units.
Note: I will post this thread in several forums to get most responses. NO JOKES PLEASE!!!
Doctor J is offline   Reply With Quote
Old 10-15-2007, 09:32 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
I did my 3sfe bearings and at over 200k they were wiped, thrust and all and the mains were just as bad as the rods, my clutch engagement is silky smooth now and i had to speed up the idle slightly, I think that if the tcc was staying slightly engaged it would get really hot and you would see nasty atf, as far as alignment your sure both dowels are there?
Old 10-16-2007, 07:55 AM   #3 (permalink)
Doctor J's Avatar
Fred, thanks for reply.
The one dowel is present, I get no chance to verify presence of other one below the distributor, but the flexplate cover seems to be aligned well.
I was also thinking, that dragging clutch will burn the ATF, considering that the problem was noticed by the owner 4000 mi ago.
The rebuild TC is painted blue so if it will overheat, the paint will change color.It still the same.
During the last oil change no metal chips was found in engine oil , as well as during the past oil changes.Today I will drive this car to get it hot and repeat my test.
The owner says that when the car is driven about 6 mi, the whine noise canges to the rattle. During the acceleration, the brief whine is present sometimes.
There is no noise at or after upshifting.
Old 10-16-2007, 10:01 AM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
there has to be 2 or it will be in a twist
Automatic tranny malfunction after engine swap (3VZ-FE) deepsun 3rd & 4th Generation (1992–1996 & 1997–2001) 20 08-07-2008 03:47 PM
torque converter om 1994 corolla 1.8, 245 guacopo@hotmail Introduce Yourself Here 1 07-18-2007 06:53 AM
Torque converter problem? Heat 3rd & 4th Generation (1992–1996 & 1997–2001) 4 05-02-2007 03:55 PM
Camry GEN 5 Lock up torque converter ToyotaToday 5th & 6th Generation (2002-2006 & 2007-2011) 5 03-20-2006 12:14 PM
torque converter? keaser06 89-95 Toyota Pickup/Hilux 3 02-21-2006 07:04 PM
