Brake Light on during hard stops? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-24-2007, 11:10 PM   #1 (permalink)
View car_boy_16's Photo Gallery
What might be wrong? Tonight I was driving kind of hard and I ended up going from 80 to 5mph very quickly and as I braking really hard the Brake inditcator light turned on! Why would it do that?
1988 Camry LE 3sfe 4A - 123k miles
...Slower than a school bus!
car_boy_16 is offline   Reply With Quote
Old 10-25-2007, 09:34 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Check your brake fluid level. You probably need to top it off. As your brakes wear they become thinner. The fluid in the reservoir is needed to press them in that extra amount and the fluid sensor is activated. Usually, it is just the brakes wearing normally. However, do keep an eye out for leaking hoses, cylinders and the like if the light comes back on soon after you top it off. Also, you need to check your brake pads to see if they need to be replaced.
Kep
3rd brake light fuse popping gameguru1360 Archived Corolla threads 4 03-15-2007 03:21 PM
brake light on? mfunk49 1st Generation (1995.5–2004) 4 02-04-2007 12:40 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
1996 Corolla Third Brake Light BigTattoo Archived Corolla threads 6 10-23-2005 12:21 PM
L.E.D. Tail/brake light & 3rd brake light conversion project eviltwin67 Camry & Solara Lounge 2 07-02-2003 10:24 AM
