1990 timing belt let go - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 06:39 AM   #1 (permalink)
View littleREDtercel's Photo Gallery
I bought my daughter a 1990 Camry 2 years ago.
The car ran strong and everything still works, even the A/C, until yesterday that is.
She called me from the side of the road and I pushed the car to a parking lot, pulled the plugs and no compression. Popped the dist cap and cranked the motor. No rotor movement. OK, the timing belt is gone. Milage is 202K.
My question is this, will this 4 cyclinder (3SFE) have valve train damage, or is there clearence between the pistons and the valve when the timing belt lets go?
littleREDtercel is offline   Reply With Quote
Old 10-26-2007, 10:24 AM   #2 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
nope everything's still fine just replace the belt and redo timing and you're good to go again.
Old 10-26-2007, 11:31 AM   #3 (permalink)
Thanks atobe, you just made my day.
Old 10-29-2007, 08:04 AM   #4 (permalink)
View tigertron's Photo Gallery
is this the same for the v6 as well or no?
tigertron is offline   Reply With Quote
Old 10-29-2007, 11:16 AM   #5 (permalink)
Jerfi2003
View jerfi2003's Photo Gallery
This also goes for the 90 camry v6. I just changed mine. Biggest problem I had was finding TDC on number 1 piston since it is basically covered up by the intake.
jerfi2003 is offline   Reply With Quote
Old 10-29-2007, 01:04 PM   #6 (permalink)
NYR
View IvanHoe's Photo Gallery
Almost ALL Nissan timing belt driven engines are interference....even the 4 cylinder ones!
However, Toyotas are just the opposite .....the only Toyota Camry interference motors are 98'+ 1MZ-FE 3.0 V6 engines.
Here's a complete listing of makes/models/engines and if they are interference or not(Originally found it on the Gen3 side of the forum):
http://www.flyupload.com/?fid=8411768
↑↑↑when you click the link, be sure to scroll down and hit 'download'
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
My Timing belt change (very detailed, pics) Gen 4 JerryGiese 3rd & 4th Generation (1992–1996 & 1997–2001) 166 04-09-2012 10:44 PM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
Timing Belt Slaps! kamrhee 3rd & 4th Generation (1992–1996 & 1997–2001) 13 07-13-2007 12:27 PM
timing belt vs timing chain ? artie in miami T-100 4 12-13-2006 11:21 PM
Changine Timing Belt..Found Oil behind Timing Covers A2brb Camry & Solara Lounge 11 11-14-2005 04:10 PM
