1988 camry will run but wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-26-2007, 03:37 PM   #1 (permalink)
The bucket owns you!
ChevelleSSLS6's Avatar
View ChevelleSSLS6's Photo Gallery
1988 camry, 4banger, 5sp.
Battery (delco 650cca) and alternator new about 8mos ago, and every so often it would need a jump start, for no explainable reason. Lights and everything were OFF.
Well, it did that to me earlier today and it wont restart once shut off without some extra juice. What's going on?
ChevelleSSLS6 is offline   Reply With Quote
Old 10-26-2007, 06:53 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Are the headlights dim during the start?If alternator is charging (check with voltmeter) and all connections are good, it could be drain possibly by the trunk light is staying on due to mis-adjusted trunk latch switch.remove the bulb and retest.
Doctor J is offline   Reply With Quote
Old 10-26-2007, 08:57 PM   #3 (permalink)
View monito's Photo Gallery
+1
alternator could be bad. hopefully you purchased one with a good warranty. Especially if it was reman'd
monito is offline   Reply With Quote
Old 10-27-2007, 10:09 AM   #4 (permalink)
View marc780's Photo Gallery
Yes it might be the alternator is too weak. You can test it yourself easily enough, to do this buy a volt ohmmeter (often called multimeter), you can get one from harbor freight for $5 or from sears for 10, start the car however you can. Let it idle for 3 minutes or more, then set your new toy to read vdc (volts DC) either the 20v or 50v setting whichever one it has.
Now just put the probes on the battery, you want to see a reading of at least 14 volts (acceptable range 13.9 - 15.1). If it is lower reading than this, check your belt for looseness and slipping (you can try and turn the alternator pulley by hand - if you can do it, tighten or change the belt). Once any belt problems have been solved, test it again, if it is still low, remove the alternator and haul it to the auto parts store to have em test it and replace it if needed.
It is better to do all this sooner rather than later because a dying alternator might take the battery with it as it goes out.
Old 10-27-2007, 10:53 AM   #5 (permalink)
Doctor J's Avatar
The rebuild alternator on my co-worker's camry had two bad diodes.The charge light was off but the car was stalling in reverse
Old 10-27-2007, 01:18 PM   #6 (permalink)
Originally Posted by marc780 View Post
...then set your new toy...
hehehe
good to know that i'm not the only one that refers to new tools and equipment as toys :P
Old 10-27-2007, 10:24 PM   #7 (permalink)
I'll have to check it out... until then, I'm Jeepin
it sucks gas (and thus money), but it's a lot prettier (and I like it a lot more) than the Camry. Camry makes for a nice, cheap to run DD though.
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Camry 2007 2.4L w/Manual transmission : Tough to start vinniemak 5th & 6th Generation (2002-2006 & 2007-2011) 4 07-07-2006 07:22 PM
1986 Camry Cold Start Problem toored 1st & 2nd Generation (1983–1986 & 1987-1991) 12 07-04-2006 08:59 AM
'90 camry won't start fsjeepers 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-05-2005 09:45 PM
