poor throttle response for a v6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2007, 12:38 AM   #1 (permalink)
View tigertron's Photo Gallery
I drove a v6 camry for the first time today and i knew something was wrong. it idles rough at times and smooth at times. Its a 91' v6 and it start up well also it passed inspection. what could this car to be so slow? is the TPS bad?my brother owns a 92' with a 4 banger and that thing is fast. can you help please cause i may consider buying it. Thanks!
tigertron is offline   Reply With Quote
Old 10-28-2007, 02:05 PM   #2 (permalink)
nobody?
Old 10-28-2007, 04:51 PM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
could be just a dirty TB. or timing's off
Old 10-28-2007, 05:17 PM   #4 (permalink)
i will try that thanks bro.
Old 10-29-2007, 07:27 AM   #5 (permalink)
seems more lively now.took it on the highway. i guess it needed a good long run. I will still give it a complete tune up. anybody know how much this will cost?
Old 10-30-2007, 03:59 PM   #6 (permalink)
View monito's Photo Gallery
If you do the work yourself, it shouldn't cost more than $200.
platinum or better spark plugs, spark plug wires, distributor cap and rotor, should cost around $60 - 90 depending where you buy parts.
case of oil and oil filter should cost around $30.
Air Filter around $10 - $30 [K&N cost about $30]
Seafoam and Deep Creep should cost you about $5/can
*edit*
I just found the receipt for the parts i bought for my tune-up earlier this year
6 Denso platinum tipped spark plugs, distributor cap, rotor, and plug cable assembly [9 items] came out to about ~$200 from the dealer. If dealer pricing is on the expensive side, you should be able to get parts for MUCH less than that @ Autozone or Kragen
monito is offline   Reply With Quote
Old 10-31-2007, 12:42 AM   #7 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Clean that throttle body out good. If you can get a gasket quickly, take the damned thing right off the intake and clean it thoroughly. You won't believe the tarry crap that builds-up in there over time.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 10-31-2007, 07:12 AM   #8 (permalink)
thanks i'll work on that today. The car is alot more responsive now BTW. it does need rear shock/struts though. which shoch/strut is the best to use all around. do you change springs as well with this.
Old 10-31-2007, 11:37 AM   #9 (permalink)
Pochacco Owns Me
atobe's Avatar
use KYB gr2 that'll be a good way to go...probbly won't have to change the springs unless it's broken in pieces
Old 11-01-2007, 10:02 AM   #10 (permalink)
thanks i will look for those.
Old 11-02-2007, 10:26 PM   #11 (permalink)
Bullitprooph
Yes, the KYB GR-2 struts are good. I've got them on both of my Camrys and on my Corolla sedan, and they last a long time with a comfy ride.
I have changed countless struts on countless Camrys/Corollas, and I have never had to replace the coils. The strut mounts, however, tend to crap-out on the rear of the Gen2 Camrys. They'll give you a clunking sound when they go.
Old 11-04-2007, 10:03 PM   #12 (permalink)
i'm hearing that too. I am getting 4 new tires and the gr2's and a tune up. Got the car on the lift and there is a leak in the power steering. thanks
Old 11-04-2007, 11:08 PM   #13 (permalink)
Bullitprooph
Wow, you're fixing everything at once! Post some pics if you get a chance, it must be a nice Camry for the effort you're putting into it...
Old 11-16-2007, 07:41 AM   #14 (permalink)
Interior is really clean, sun roof. It needs a paint job as the hood and trunk are faded. usual rust on the rear fender trim. Its is a New york car. I need to make it road worthy asap. I just got a quote from my brother. 255 bucks for the 4 shocks with brake pads/rotors 12 bucks for each axle boot. i need my tune up parts list and ball joints next and finally an alignment/tires and i am good for the winter.
ps clean throttle body out good. By next week all this should be done.
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
List of V6 5-Speed Camry's I found currently for sale ASG14 Camry & Solara Lounge 13 10-22-2006 05:59 AM
Toyota Tacoma lexusis350 Toyota News 12 10-28-2005 02:15 PM
96 Camry V6 LE: TRD supercharger? kman10587 3rd & 4th Generation (1992–1996 & 1997–2001) 11 07-16-2004 03:15 PM
