Ageing Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-28-2007, 12:26 PM   #1 (permalink)
View Gerry Storm's Photo Gallery
Ageing Camry
I have a 1986 LE which I have owned for over 7 years. It currently has 152K and is in generally fine condition. However, it is plagued by an unpredictable neutral start switch problem. The shift mechanism (auto) seems to have too much play as well. I read in the manual that alignment of the shaft is critical. Sometimes when it won't fire I can lift the hood and jiggle the various wires near the starter and apparently cause the switch to engage...A new switch costs around $175 and I will likely wind up buying one soon but I still wonder if the problem could be in the loose shift assembly. Would appreciate any input from others with knowledge of this problem and potential solutions. Thanks.
Gerry Storm is offline   Reply With Quote
Old 10-28-2007, 02:46 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Some times taking the switch apart and cleaning contacts inside could help.
Doctor J is offline   Reply With Quote
Old 10-31-2007, 11:57 AM   #3 (permalink)
Gameroom cash: $302555
Are you sure it's the neutral start switch and not the common starter motor solenoid contacts problem? Do a search on this site for "starter contacts", if you are not familiar with it. Moving things in the vicinity of the starter can possibly cause enough vibration to the starter itself, jarring the contacts just enough and causing them to make beter contact and work again. Just a thought.
Mike
2008 Camry vs Accord vs Passat, showroom impressions (long) woodman411 5th & 6th Generation (2002-2006 & 2007-2011) 50 09-22-2007 06:03 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Toyota Camry Stereo Information '83-'00 AllMadd Camry & Solara Lounge 2 08-09-2007 08:11 AM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
