Shake Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2007, 09:54 AM   #1 (permalink)
2G_Panda
Kuler2.0's Avatar
View Kuler2.0's Photo Gallery
2nd Generation Shake Problem
So I was driving home from work yesterday and noticed that I have a small shake in the front end of my 87 Camry DLX (I can't tell what side) when I hit about 80 MPH. It shouldn't be alignment because the car was aligned not that long ago. The only other things I can think of are my bad suspension (which I am trying to get fixed) or a wheel Berring possibly going out. Does anyone have any other ideas? Any input would be helpful to help me diagnose the problem. Thanks.
Jay
Kuler2.0 is offline   Reply With Quote
Old 10-29-2007, 10:04 AM   #2 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Worn front suspension components could sure cause it. Other things would be a bad tire, or a wheel out of ballance. Why did you have an alignment done if you know you have bad suspension parts? The alignment specifications are based on a car that is sitting at stock height and has no wear or play in the front end.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
Old 10-29-2007, 01:25 PM   #3 (permalink)
NYR
View IvanHoe's Photo Gallery
try speed balancing your tires, I had the same issue from a shop that did a piss poor speed balancing....I brought the car to a different shop and had them re-do it and all is well!
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 10-29-2007, 01:45 PM   #4 (permalink)
2G_Panda
Kuler2.0's Avatar
2nd Generation
The balancing is a good point. The reason the car was aligned on bad shocks was that I needed new tires ASAP (they were bulging from dry rot) and didn't have time to do the suspension first. It sounds like it is probably going to be one of those issues so I am going to do the suspension and see how it goes from there. Thanks for the input.
Jay
Old 11-02-2007, 09:56 AM   #5 (permalink)
Friend of Toyotas
RedSIBaron's Avatar
View RedSIBaron's Photo Gallery
wait so you woulnt align your car if you had worn suspension components? i know he already said cuz he had just gotten tires, i know i remember when he bought tires...but seriously, dont give people advice like "dont align your car"...even if your suspension is beat a proper alignment makes almost as much difference for performance as your dampeners on the suspension...if a car is not properly aligned it can make the handling characteristics extremely unpredictable...not to mention the tirewear you can have with even a slightly off allignment...
also since no one has mentioned it, what im guessing kuler's problem is, since it gets a wobble and there is also a knocking sound when the suspension is under load, is that he has worn outter tie rod ends...it would also explain the slop in his steering...we shall see when we do his suspension work hopefully next week...
Hondas
Toyotas
& BMWs
Helping each other for the greater good
rolling on 13s/14s/15s We is BALLER
RedSIBaron is offline   Reply With Quote
Old 11-02-2007, 10:15 PM   #6 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
This almost definitely is NOT your problem, but twice now I've had the front p/s caliper on my V6 seize and cause vibrations--but only intermittently. I think it was seizing slightly (maybe a small groove in the piston bore) and causing the rotor to heat-up only at highway speeds. This did not happen at city speeds. Once the entire steering knuckle was super-heated, it likely caused the brake fluid to expand considerably, causing the caliper to seize even more. Most unexpected vibration diagnosis I've ever had to fix.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Rear Shake Problem - Help! madibob 1st Generation (1995.5–2004) 5 07-19-2007 12:39 PM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
