I unscrewed the female cable end from the transmission, then removed the keeper bolt and flat metal keeper. Then I removed the cylindrical aluminum housing that holds the gear. I expected to find this gear either broken or missing but that was not the case. After inspecting inside the hole left by removing this piece I came to the conslusion that there was nothing for the small gear to mesh with inside the transmission. Unless I have completely missed the boat, I am assuming that there should have been some kind of gear inside and that it must have been removed or is broken.
