Gen 2 Wagon Rear Speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-29-2007, 05:24 PM   #1 (permalink)
View laraz629's Photo Gallery
2nd Generation Gen 2 Wagon Rear Speakers
I've got a 1988 camry wagon and I am trying to replace my blown factory speakers. I have not been able to find anything about how to get to the rear speakers. I need help with the 2 woofers on the sides as well as the 2 tweeters on the ceiling of the trunk.
Any info would be much appreciated.
Also, does anyone know anything about how much power the factory radio gives out to the speakers (wattage and resistance)?
Any more info on the factory stereo system? Still considering all of my options, any info on the stereo not found elsewhere in this forum would be great!
laraz629 is offline   Reply With Quote
Old 10-31-2007, 07:32 AM   #2 (permalink)
View misha9573's Photo Gallery
2nd Generation
I've got a '90 wagon and I replaced those a couple years back. Hmmm, if I remember correctly I took the following steps to get to them:
1. Remove trim at rear door (top and bottom)
2. Remove nearby hooks (at sides of door opening)
3. Remove back seat side padding (both sides, basically to expose part of wheel well trim)
4. Remove side window trim panels (be careful here, I broke some tabs and I've regretted it since)
5. Finally remove wheel well trim panels (you'll have to raise the spare wheel cover) and voila! the rear speakers are exposed.
Now I know I've not been as detailed as I should have, but that's about the gist of it (I hope I haven't forgotten anything). I should have some diagrams in a box somewhere. I can't promise anything, but I have a look on Sunday.
The tweeters on the ceiling are easier, just slide a flat tool (panel remover or putty knife) under them and carefully pry them up...I can't remember which side the tabs are on. I can check later.
I think the stock head unit powered 4 watt speakers up front, and 10-12 watt in the back...but I'm not sure, my memory isn't that good beyond a few months They were all 4ohm though, that I do remember.
Hope I've help out a little, I'll try to get more info for you. I had fun replacing my entire audio setup, so should you.
Cheers
misha9573 is offline   Reply With Quote
96 Corolla Rear Speakers chenj16 Audio, Video, and Security - Tech 13 02-16-2012 10:23 AM
2001 Corolla Rear Speakers Rico Audio, Video, and Security - Tech 9 01-04-2006 06:33 PM
Rear End GEN 4 To GEN 4.5 Conversion... leasaunce 3rd & 4th Generation (1992–1996 & 1997–2001) 24 11-12-2005 05:03 PM
gen 4 rear disk = gen3 rear disk? confirm? itzsteven 3rd & 4th Generation (1992–1996 & 1997–2001) 3 12-01-2004 03:07 PM
Gen 2 Camry rear speakers Question epborden Audio, Video, and Security - Tech 3 01-23-2004 04:56 PM
