How do I remove the heater controls? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2007, 04:04 PM   #1 (permalink)
View nuron's Photo Gallery
I have the manual, not the electronic one, so there's wires and hooks behind the controls that I don't know how to remove. I'm having trouble with the middle part in general as I am trying to remove my dash pad. Thanks!
nuron is offline   Reply With Quote
Old 11-03-2007, 06:49 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its easier to unhook the cables from the other ends rather than from the control head
Old 11-04-2007, 03:42 PM   #3 (permalink)
Ok I need some extra help here, been at it for two hours now trying to remove it. It's a sunday so the yards are closed and I seriously need to wrap this up on my free day. fredk, what do you mean by unhook the cables from the other end? On the blower itself? It looks hard. When I try to pull the center piece towards the front, there's only so much slack that the cables give me so I end up having like an inch of room to look at the cables and do all the work, which doesn't work at all. Please help!
Old 11-04-2007, 09:11 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
follow the cables to the other ends and unhook them there
Old 11-10-2007, 05:40 PM   #5 (permalink)
Wow I din't think it was going to be easy like that haha, oh how the simplest things escape us. So I finally got this thing out, after much frustration.
I had lots of trouble with this one. Is there a tool with a 90-degree bend to access this?
Old 11-10-2007, 10:51 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
ya did it, now clean everything with compressed air
Old 11-10-2007, 11:11 PM   #7 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
what ya doing ?
Old 11-11-2007, 02:52 AM   #8 (permalink)
Alright I'll clean it with compressed air the next day I'm free. I wonder if creating a tighter seal with the vents will make my windshield defog faster...
atobe, I'm trying to replace the dash pad because the two outermost vents are cracked and broken, the middle ones do not alternate between the types of venting, mainly the three unsightly cracks you see on the right.
Old 11-18-2007, 03:36 AM   #9 (permalink)
Alright I have the new dash pad installed. Ran into some little things like the cables affecting the slider on the heater control from moving fully and heat not working. The cables have little color markings at the ends and the section with the paint should match with the clip when you clip it in. If you have the old style cluster cover (with the hazard and defog buttons on it) they'll fit on the newer dashes but the newer cluster cover won't work with the older connectors as they are different.
One thing though: the On option that the domelight has (on, off, door) won't work anymore for me for some reason after the swap. I have two units and they're both the same.
93' Heater failure. Possible thermostat failure? Yota_master 89-95 Toyota Pickup/Hilux 9 10-22-2008 10:25 PM
Changing the front axle hub bearing bigbikes2003 1st & 2nd Generation (1983–1986 & 1987-1991) 3 07-01-2007 12:54 AM
Rattling noise from my heater core on my 02 Camry kalinaprobe 5th & 6th Generation (2002-2006 & 2007-2011) 0 01-02-2007 01:52 PM
Need to get heater core out Ferrat Camry & Solara Lounge 3 06-13-2006 08:02 PM
22R Cold Mixture Heater? bs1231 Pre-88 Toyota Pickup/Hilux 3 05-09-2006 09:47 AM
