1989 Camry Torque Converter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-07-2007, 11:57 AM   #1 (permalink)
View VancouverVan's Photo Gallery
Good morning -
my niece's '89 Camry, 4-cylinder, automatic, was flinging oil out the bottom of the bellhousing, visible through a small hole in the tin....
It seemed to be motor oil, and the motor oil dropped, while the tranny fluid did not.
I assumed the main seal was bad, and it's torn down.
When I separated the transaxle from the engine block, what appeared to be dirty tranny fluid flowed out of the torque converter, from the hole where the tranny shaft would slide in.
Is that normal? Upon reassembly, when I refill the tranny with new fluid, does the torque converter drink from the same supply?
Thanks!
VancouverVan is offline   Reply With Quote
Old 11-07-2007, 12:15 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The transmission fill tube fills the transmission and torque converter. There is a separate reservoir (at least in the older Camrys) for the differential fluid. If you decide to change the differential fluid make sure that you can open the fill port before you drain the fluid. Sometimes the fill port is stuck and if you drain the fluid out then you are stuck until you can get it fixed. If memory serves, the 1990 model used 12 quarts for the transmission and differential but only drained out two quarts from the pan.
Kep
Old 11-07-2007, 01:42 PM   #3 (permalink)
So - the tranny fills via the dipstick accessed at the front of the motor, driver's side of engine, and this also fills the torque converter.
There's also a differential, with separate fluid? The things I learn on-line....
So - do I assume from Kep's answer that fluid SHOULD drain out of the torque converter once the transaxle is removed from the motor?
Thanks!
Old 11-07-2007, 09:06 PM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
the diff fill/drain is different place... it's above the cross member...around the back of the tranny if you will.. you should find it easy if it's out of the car.... and yes the dip stick will fill the tranny + torque converter.
Old 11-07-2007, 09:50 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
there is a pump in the trans driven by the converter that circulates the fluid in the trans and converter and it powers all the servos and clutch packs and all, but the diff where the axles go in is a separate compartment and the fill plug is a MF to get to, its on the back side abou half way up
Old 11-11-2007, 09:01 PM   #6 (permalink)
Thanks for the advice, all - here's my plan:
replace the main seal as planned,
drain tranny and refill once re-installed - is there a filter on that, as there was on the old Chevy turbohydromatics?
open the fill port on the transaxle, drain it, and refill it before reinstalling...
Also planning to replace the belts, timing belt, front seals, and water pump while I have it out, but haven't gotten far enough in to generate any confusion....I've done Fords, VW Diesels, Chevy's...this'll be my first Toyota timing belt.
Looks normal in the book...
Old 11-28-2007, 10:33 PM   #7 (permalink)
Transfer case fluid
Greetings- on the '89, I know it's ATF in the TC and into the transaxle via the dipstick...but there's a transfer case, also, right? Even though it's 2wd.
It's got a bottom drain plug and a side fill hole - the sort where you fill it till it runs out.
My manual's poor on this point - does this thing take ATF or gear oil? What I drained out ran thin like way-used ATF, but there was very little of it - maybe a pint.
Any advice?
Thanks!
Old 11-29-2007, 07:55 AM   #8 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
No.
The torque converter will have fluid in it. To drain it, you need to pull it off the tranny and dump the fluid out.
Tranny and differential take Dexron II or III ATF. I don't think Dexron II exists anymore, so use Dexron III.
"Skoolin' the unlearned!"
02 Camry Se Cat Converter Camuser15yrs 5th & 6th Generation (2002-2006 & 2007-2011) 0 10-20-2005 07:02 PM
1989 Std Camry Sway Bar Options sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 17 09-15-2005 08:43 PM
Gen 3 Torque converter clutch lockup JasonH 3rd & 4th Generation (1992–1996 & 1997–2001) 0 04-16-2004 09:47 AM
FS: 1989 Toyota Camry V6 shuluke Vehicles 0 03-23-2004 09:01 AM
1989 Camry, 4dr Vandalized... Steering Column replace ? sdhartney 1st & 2nd Generation (1983–1986 & 1987-1991) 12 02-27-2004 06:16 AM
