engine problems
I got an 86 camary that had a blown head gasket. I took it(EFI 2.0) all apart and while it was apart I ground the valves. I put it back together and instead off a vacume I was getting air coming out off the intake. I took it apart again and all the lifters were stuck in the all the way up position. I figured that was the problem since I ground the valves maybe it was holding the valves open. I put it all back together and it still does it. I had marked the timing belt and gear so it should be where it was. Any ideas?
