High Idle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2007, 01:23 AM   #1 (permalink)
View Lee250's Photo Gallery
High Idle
I just changed the head gasket on my 86 2s-e and before putting the intake back on I removed all vacume lines except fuel pressure regulator, PCV, brake booster and that other line on the valve cover. I took all the other ones off to save future problems with the old lines and to cut down on engine compartment clutter. I used a digital timing light to set my timing and according to the timing gun my engine is idling at 1,000 rpm. The set screw for the idle adjustment is backed all the way out and it is still 1,000 rpm. All vacume ports on intake are plugged and as far as I know there are no vacume leaks. It runs perfectly with no problems it just idles high and I was wondering what it might be.
Lee250 is offline   Reply With Quote
Old 11-28-2007, 04:21 PM   #2 (permalink)
View marc780's Photo Gallery
did it idle right before you did all the work? If so i think i'd put the vacuum hoses back the same way they were when the factory put them on when they made the car...maybe just plugging the vacuum ports on the intake is not the way to go if you want the car to idle right
22RE T100 Idle is HIGH, LOW when pressing brakes ultrasonic T-100 2 09-06-2008 09:55 AM
High Idle @ startup hughesar 2nd Generation (2000-2004) 8 10-04-2006 02:27 PM
3VZ-FE, high idle mazdaverx7 Camry & Solara Lounge 10 08-20-2005 07:49 PM
1993 V6 high idle... AlphaMale 3rd & 4th Generation (1992–1996 & 1997–2001) 6 01-11-2005 07:00 AM
