Starting troubles - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 11:28 AM   #1 (permalink)
View Robskidoo's Photo Gallery
Starting troubles
I have a 91 camry. I was parked with the engine on and it just cut off and hasnt started since.... no i have power going into the coil but its not coming out and im not getting a spark from the sp. it cranks but the engine never turns over.... does any one know what could cause this or am i looking in the wrong place for the problem???
Robskidoo is offline   Reply With Quote
Old 11-18-2007, 01:12 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Have you determined if your timing belt has broken? An easy way to do this is to remover the distributor cap and crank the engine. If the rotor doesn't move, your timing belt is broken.
Kep
Old 11-18-2007, 08:43 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
if the cam is turning it might be coil time
Old 11-18-2007, 10:09 PM   #4 (permalink)
changed the coil and nothing happend
Old 11-19-2007, 09:57 AM   #5 (permalink)
View wiccanferret's Photo Gallery
Did you do the timing belt test?
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
1995 Toyota T100 SR5 Starting Troubles toyotakev T-100 13 05-03-2007 08:34 PM
Starting Troubles on a 2005 newell1026 Archived Corolla threads 6 01-29-2007 04:33 PM
94 Lexus ES300 Starting Problem starry012 General Lexus Discussion 0 10-03-2005 01:21 PM
87 4runner not starting chronoti 4Runner Lounge 2 10-13-2004 02:21 PM
Starting problems - Electrical. pdrover Archived Corolla threads 12 02-09-2004 03:55 AM
