Manual Transmission Leaking? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2007, 11:19 PM   #1 (permalink)
View scribby's Photo Gallery
Hi,
Ive just replaced my CV shaft say 3 days ago, and while I was under there I noticed that there appears to be a leak coming from the drivers side of the transmission. Looking closer seems to be coming from where the driveshaft enters the transmission, is there a seal or something that may need replacing?
I'm thinking of just dumping all the ATF, and putting in gear oil hoping that will fix the leak.
Any suggestions as to what it could be?
1990 Gen2 - 305,000KM
Gen 2 - 6 Camry Manuals!
scribby is offline   Reply With Quote
Old 11-19-2007, 01:55 PM   #2 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
It is just a damaged seal... pop the axle back out, replace the seal and put the axle back. Next time, be more careful when you replace the axle.
-Charlie
Old 11-19-2007, 09:41 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
the rubber in the seal is all cracked up, just change it
Old 11-19-2007, 10:43 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Stick with ATF if it's a four cylinder. Gear oil is only for the V6 manual trannys, might be waaaay too viscous for your rig.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-20-2007, 02:03 AM   #5 (permalink)
Thing is I only replaced half the CV Shaft, I didn't even take anything out of the transmission. So how can the seal be accessed? Just pop the shaft out and where and how would I get to it?
Toyota sent out a TSB in 1991 to change from ATF to gear oil, so it should be fine.
Old 11-20-2007, 09:41 AM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
large screwdriver works well
Old 11-20-2007, 01:09 PM   #7 (permalink)
Bullitprooph
Two large screwdrivers work even better. I like being able to pry back-and-forth between the two drivers, you don't have to use as much force to pop the snap-ring out.
Old 11-20-2007, 08:25 PM   #8 (permalink)
Will the seal come out once I've popped the shaft out? What do I ask for when I goto the auto place to get a new one? I'm not all to keen to pop everything out until I have a new on in hand lol
Complete 5sfe Manual Transmission swap! DAMON Car Parts for Sale 6 03-07-2007 09:01 PM
Manual Transmission rocks RAV4EVR 5th & 6th Generation (2002-2006 & 2007-2011) 17 01-04-2007 12:29 PM
Found a $350 camry, but not sure if i can fix it Figit090 1st & 2nd Generation (1983–1986 & 1987-1991) 37 01-02-2007 02:29 PM
Manual transmission oil change thebigron Pre-88 Toyota Pickup/Hilux 4 12-14-2005 05:13 PM
Manual Transmission Hybrids ? RAV4EVR Toyota News 12 08-01-2005 08:27 PM
