instrument cluster with tach - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2007, 06:06 AM   #1 (permalink)
View MROLDV8's Photo Gallery
Question instrument cluster with tach
Looking at some of the Gen 2 photos on this site, I noticed an instrument cluster with a tach in place of the giant fuel guage that my '90 has. If I were to find one with a tach at my local wrecking yard, would it just 'plug and play' in my car or is there any re-wiring I'd have to do. Even though it's an automatic, I just don't like driving without a tachometer.
MR
MROLDV8 is offline   Reply With Quote
Old 11-21-2007, 08:40 AM   #2 (permalink)
Friend of Toyotas
RedSIBaron's Avatar
View RedSIBaron's Photo Gallery
should be plug and play man, we went to bestlers pull and pay in northern kentucky (exit 8 after the cinci airport exit on 275) and they have A LOT of camrys, shoudl be atleast one with the cluster if you dont have one already...
Hondas
Toyotas
& BMWs
Helping each other for the greater good
rolling on 13s/14s/15s We is BALLER
RedSIBaron is offline   Reply With Quote
Old 11-21-2007, 10:41 AM   #3 (permalink)
Smile
Thanks a lot...that's good news. There's a pull-it-yourself yard in Milford near where I work. If they don't have one I'll give Bestlers a shot.
MR
Old 11-21-2007, 11:14 AM   #4 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
you can also swap over your odometer so you won't end up with some cluster with like 200k miles
Old 11-21-2007, 11:31 AM   #5 (permalink)
LOL...I have 198K on it now.
MR
Old 11-21-2007, 01:22 PM   #6 (permalink)
Friend of Toyotas
RedSIBaron's Avatar
how do you swap over hte odometer? kuler2.0 would like that im sure
Hondas
Toyotas
& BMWs
Old 11-21-2007, 06:23 PM   #7 (permalink)
NYR
View IvanHoe's Photo Gallery
If you do a search, there are threads that already have dealt with this very subject.......
I replaced my gauge cluster for the Tach cluster, and YES, it's plug and play for sure......junkyards charge around 40-50 us for them and they are around on eBay as well......
It's a 5 minute swap....MAX!
It's not 100% the same odometer, the old one wont screw into the tach cluster....at least without not some mods.....
1991 Corolla LE - 5 speed
IvanHoe is offline   Reply With Quote
Old 11-21-2007, 07:05 PM   #8 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Make sure you get one from a car that has the same motor as your car. If not, the tach will read wrong.
I have successfully swapped the complete speedometer section from one cluster to another with no problems or modifications. For registration purposes, I wanted to keep the odometer correct. Your best bet to make sure they match is to get either a late model ('89-91) or early model ('87-'88) to match your car (check the way the speedo is marked to see the difference).
-Charlie
Old 11-21-2007, 11:08 PM   #9 (permalink)
NYR
-Charlie
I was wrong about swapping the speedo, no mods are needed, but I remembered why I didnt do it....I was nervous about pulling the needle off and screwing up "true zero"....
another thing about making sure you get the correct engine cluster is besides the accurate tach(different redline),...the speedo on the v6 is also different from the 3sfe ones(tire size differences between the 2 options)
Old 11-22-2007, 11:52 AM   #10 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
HOLY CRAP, your yards charge that much for a 17-year-oly guage cluster?!?! The list price where I work is $22 and I usually charge my customers $10.
Also: what trim level came without a tach? Of the 4-dozen or so Camrys that I've seen in our yard, every single one had a tach. When I think of it, tho, we've never had a "DX" model in our stock...being the Sherlock I am, I begin to suspect it is a US-only thing.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 11-22-2007, 08:37 PM   #11 (permalink)
white90dx's Avatar
Speedos are compatible between the V6 and 4 cylinder. The max reading is different and the odometer won't match. The difference in rolling diameters between the 14" steelies and 15" alloys is minimal with the correct size tires.
You don't need to pull the speedo needle to swap the speedo. Don't pull it. There are three screws on the back and it pops right out as a complete assembly.
Tachs are incompatible because the will read wrong - not because the redline is wrong (though it also is). The tach is based on how many ignition pulses there are (3 per revolution on the V6, 2 per revolution for the 4 cylinder). A V6 tach on a 4 cylinder will read low and a 4 cylinder tach on a V6 will read high.
-Charlie
PS. Yes, I have tried most of these combinations.
Old 11-23-2007, 11:01 AM   #12 (permalink)
View typesix's Photo Gallery
"Even though it's an automatic, I just don't like driving without a tachometer."
Used to think like that when only 3 speed trannys were around, but have found that having a tach on auto tranny is more necessary than on manual for knowing what gear is in use to maximize mpg.
typesix is offline   Reply With Quote
Old 11-23-2007, 01:29 PM   #13 (permalink)
NYR
Old 11-24-2007, 03:54 PM   #14 (permalink)
View sillysspeed's Photo Gallery
Switching the gauge cluster is a good mod!!!! I switched out my odometer to read the correct mileage too.
sillysspeed is offline   Reply With Quote
Old 11-24-2007, 05:16 PM   #15 (permalink)
Going to rainforest, BRB
HomeGrown's Avatar
Gameroom cash: $160385
View HomeGrown's Photo Gallery
-Charlie
This subject comes up on every cluster swap thread I've seen. There are certain circumstances in which you DO have to pull the needle and swap speedo face-plates. I had to do that with the '89 (IIRC) cluster that I put into my '91. The mounting screw locations were different from one to the other. It was really no big deal to pull the needle though. It was either that, or instantly have 80k more miles on my car.
2011 Regular Cab, 4x4 Auto, N-Fab step bars, Satoshi grille, OEM fog lights, Extang Trifecta cover (list growing, check back often!)
HomeGrown is offline   Reply With Quote
DIY write-up for instrument gauge cluster lexusk8 8th Generation (1998-2002) 30 11-27-2011 11:40 AM
Instrument cluster w/tach into 97 ? bobfur Previa Forum 2 09-04-2007 07:47 PM
AE-92 Instrument Cluster fistofmeat Archived Corolla threads 15 08-18-2006 10:26 PM
Help with instrument cluster! Crazy-Horse Archived Corolla threads 7 01-12-2006 07:38 PM
1992 Corolla DX Customer Instrument Cluster garryconn Archived Corolla threads 2 04-24-2004 10:07 AM
