Grinding noise...??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-28-2007, 06:53 AM   #1 (permalink)
dhamaka127's Avatar
View dhamaka127's Photo Gallery
Question Grinding noise...???
When I am taking off from a stand still and press on the gas with the car in Drive. I hear a grinding noise. I would hear it only if i press on the gas a with a little bit of a heavy foot, otherwise I dont hear it if I gently let on it. This is also only happening from a stand still and taking off. while i am driving and i press on the gas i dont have any grinding noise.
I have talked to a few people and they said that its probably the torque convertor.
I would just like to hear from some Yota owners out there....
Thanks in advance...
1990 Camry DX
dhamaka127 is offline   Reply With Quote
Old 11-28-2007, 08:09 AM   #2 (permalink)
View wiccanferret's Photo Gallery
If others have heard it and say it's the torque converter then I'm sure you could benefit from a transmission flush. That's where I'd start.
Another thing that makes noise when you punch it but not when you take off gently, in my experience, is failing motor mounts. You can check that by watching the engine as someone puts their foot on the brake and hits the gas a bit with the car in drive. If it looks like the engine is going to come out and see you, you have a motor mount out.
I'm strongly against picketing, but I'm not sure how to show it...
wiccanferret is offline   Reply With Quote
Old 11-28-2007, 08:14 AM   #3 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
The torque converters most of the time are
making whining noise, similar to electric motor. Grinding is most likely produced by damaged thrust bearing (input shaft, output shaft, differential).Check if the differential is not empty.
Doctor J is offline   Reply With Quote
Old 11-29-2007, 05:43 AM   #4 (permalink)
dhamaka127's Avatar
Thanks for the replies. I told my mechanic about this. He is going to take a look at it for me.
Let's see what he comes up with for this prob.
1990 Camry DX
Old 11-29-2007, 07:50 AM   #5 (permalink)
Doctor J's Avatar
Please have us informed, as according to many so-called Toyota "experts" the TC failure on generation 2 camry is very rare.
Old 11-29-2007, 09:10 AM   #6 (permalink)
I know one thing, when the engine blew on my '90 Camry and I went looking for a car with a good engine to steal the engine and sell the rest of the parts, or even one with a blown transmission to swap my good one into, all I could find was other 2nd gen Camrys with blown engines...lol.
Old 11-29-2007, 05:52 PM   #7 (permalink)
dhamaka127's Avatar
Hey guys, I picked up my car today....
The transmission was flushed recently (6 months ago) so I did not need that. After the job I took a ride with the mechanic and he said that there is a bit of grinding but he said that the crank /cam shaft seals are perfect no breaking...nothing of that nature.....
He replaced the timing belt, drive belts, and the water pump....everything else is good to go....
The grinding noise decreased allot but it is still there....still there...We also checked to see if there was NO grinding noise when I held the brake and stepped on the gas...
He said that he does not feel its a torque converter issue...
He recommended that I use Risoline during the next oil change to clean off the heads. Also the oil change after that to use STOP LEAK for that oil leak that I have, the leak is from the head gasket.
1990 Camry DX
Last edited by dhamaka127; 11-30-2007 at 07:26 AM. Reason: Add more information...
Old 11-30-2007, 10:35 AM   #8 (permalink)
Doctor J's Avatar
Oil stop leak will not stop the oil leak from the head gasket, it could only clog up the oil pump pick up screen.
The oil leak from the head gasket in the area below the oil pressure switch is caused by slight flattening of the copper sealing ring around the opening in the head gasket . The high pressure oil is oozing past this ring and usually spreads over the engine block under the exhaust manifold.
If grinding noise is present only when accelerating the car, (not the engine in park or not during the stall test) and is suspected to be from transmission, the pan must come out to inspect for metal fragments) also check the front wheel bearings.
FLUSHING THE TRANSMISSION AS WAS SUGGESTED IS TOTALLY MEANINGLESS !!!
The additives such as Trans-X could help to cure shift quality/shudder complaints, but they will not fix the falling apart roller thrust bearings.
Old 12-02-2007, 06:29 PM   #9 (permalink)
dhamaka127's Avatar
I had the transmission flushed a little while back so its not a big deal....
I will check out Trans-X issue...anyways....
Thanks for help guys...
1990 Camry DX
grinding noise in 95 tacoma 4x4 jon08 1st Generation (1995.5–2004) 1 03-20-2007 10:20 PM
Grinding noise when using the Air condition aamercado 2nd Generation (2005+) 4 02-10-2006 11:00 AM
95 Corolla Grinding Noise Ukrainian102 Archived Corolla threads 9 12-06-2004 07:51 AM
Grinding noise when braking samp55 Archived Corolla threads 1 06-21-2003 07:18 PM
