Brake pad clips rub on rotors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2007, 12:40 AM   #1 (permalink)
View nuron's Photo Gallery
For a while now there's been a squeak whenever I brake--changed to newer pads and used that anti-squeal fluid thing to no solution. When I took off my rotors a couple days ago to machine the rotors, I found that the anti-chatter clips (V-shaped) are rubbing on the outer edge of the rotors! I've bent the rubbing sides up but it's still doing it...Can I take the clips off?
nuron is offline   Reply With Quote
Old 12-14-2007, 08:27 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I've actually never used those v-clips. I just put anti-squeal shims on the pads and that's all I need. I've never had a problem without the clips. On the other hand, I can't figure out how they would be rubbing on your rotors, either. They're bent specially to avoid that, and I've never seen one rubbing on any of the cars scrapped where I work... did they come with the new pads, or were they the original OEM ones?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 12-14-2007, 01:04 PM   #3 (permalink)
Gameroom cash: $302555
I would just try a new set of V-springs, although I doubt they are your problem. They are so thin that if they were actually rubbing on the rotor, they wouldn't last very long. In any case, see if you can pick up a new set of V-springs at the dealership and try them. I don't know if they sell them seperately, but if they do, they should be pretty cheap.
Mike
Old 12-14-2007, 02:56 PM   #4 (permalink)
89 2wd's Avatar
View 89 2wd's Photo Gallery
On some car's I have only seen them on the front of the caliper bracket (1 per side per pad). I think my car has 2 per pad (front and back). You can try bending them back out, or just get some new ones from the dealer or junkyard. I bent mine back out since doing the brakes (had the same problem) and they've been fine since.
'01 Tundra SR5 2UZ-FE 2WD
'89 X-tra cab 22RE 2WD
'91 SR5 4Runner 3VZE 4WD (sold)
'88 Camry LE 3SFE (sold)
89 2wd is offline   Reply With Quote
Old 12-14-2007, 03:00 PM   #5 (permalink)
View toyomoho's Photo Gallery
The clips should clear the rotor. Are the pads too far forward toward the rotor or clips bent?
Old 12-14-2007, 06:34 PM   #6 (permalink)
Bullitprooph
toyomoho raises a good point. If the spring clips (that hold your pads in place on the torque plate) are worn or missing, the pads will not seat firmly. They will move around, possibly causing the v-clip to touch the rotor at its outer diameter.
In fact, very occasionally these spring clips can cause the squealing sound as they touch the rotor.
Old 12-16-2007, 02:05 AM   #7 (permalink)
The spring clips are snug on the pad but still allow the pad to fall 'in' towards the rotor. Are they supposed to be tight that it's hard to move the pads in any direction? The clips came in a set from rockauto.com and prior to that, I looked at my old spring clips and they had the same wear marks from rubbing on the rotors too. It just kind of 'recently' happening though...
Old 12-16-2007, 01:38 PM   #8 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Is it possible to put them in backwards?
Kep
Old 12-22-2007, 11:50 PM   #9 (permalink)
View brohawk's Photo Gallery
i just changed my front pads in my sv21 and one side should have had 4 clips but only had 1, today while driving it felt like my breaks were on and it smoked for a bit is this because the pads were rubbing against the rotor non stop due to not having the clips in to hold the pads?
brohawk is offline   Reply With Quote
Old 12-28-2007, 08:18 PM   #10 (permalink)
any help here????
Old 12-28-2007, 10:27 PM   #11 (permalink)
Bullitprooph
Just to be clear here: When you refer to the four clips, do you mean the little spring-clips that hold each pad in place on the torque plate? There should be two of these clips holding the inboard pad in place, and two holding the outer pad still.
If these are the clips you mean, then you absolutely have to replace them. You can get a quick set from a u-pull-it scrap yard, or you can order from the dealer and wait a day or two. Either way, get 'em replaced. The pads will clunk around, may even get wedged sideways between the caliper and the rotor. Bad, bad news...
Old 01-18-2008, 02:58 PM   #12 (permalink)
After taking off the V clips, the squeaking kind of went away. But another thing came up where when I brake there is a rapid chatter-like movement somewhere up front?. Any ideas of what could cause that?
Old 01-23-2008, 11:43 AM   #13 (permalink)
Wait, haha I did take off the anti-chatter clips as they are called so I wasn't thinking straight. But yeah, even with the clips off, there is some intermittent squeaking now that I've taken those v-clips off. There's no play on the caliper, as I try to line those long bolts up. The clips are on snug also. Sigh, I don't want to buy another set of v-clips...
Old 01-25-2008, 03:44 AM   #14 (permalink)
Argh the dealer wants $33 for the hardware kit or something like that. Should I get the Raybestos kit again or something different? I bought the Raybestos before and just took them off because of them rubbing on the rotors.
http://www.rockauto.com/catalog/x,ca...t,partGroup,14
First one of the list.
Old 01-25-2008, 09:48 PM   #15 (permalink)
Bullitprooph
Well, since the kit includes those spring clips, you may as well get it (under $8 is cheap). I had to buy just one of those little clips from Toyota and it cost me $3. Unreal...
I'm still not clear on the reason for the chattering when you remove the V-clips. I have never used them, ever (six Toyotas and counting). And I have never had chatter from the pads.
IIM - Ksport Procomp Big Brake Kits - 8 PISTON!! ImageInMotion Supporting Vendor Sales 8 07-08-2008 12:21 AM
Brake rotor: Drilled vs. Slotted 95PimpingCamry 3rd & 4th Generation (1992–1996 & 1997–2001) 44 08-16-2007 06:58 PM
StopTech Axxis Brake pad lexsc4 2nd Generation (2005+) 1 01-26-2007 09:33 PM
2003 Camry LE Brake rotors Dylansdad 5th & 6th Generation (2002-2006 & 2007-2011) 4 04-03-2006 08:52 PM
Good discussion on x-drilled/slotted brakes EKam Hardcore Tech and Competition 44 12-29-2003 11:46 AM
