Might want to do a full flush
Now that the trans is still holding together (many trans's that have old nasty fluid showing signs of failure often fail soon after the fluid is changed), you might want to flush all of the fluid in the trans. You only changed about 3-4 qts of about 9qts of fluid. It's not that difficult to do at home.
Buy a case of appropriate fluid. Find the trans cooler hose that goes to the radiator and disconnect. Add another piece of hose to the radiator where you just diconnected and run both loose ends into large container (i.e. 2 gallon container should do it). You may need the car on ramps to do this, and may have to secure the hoses if you're doing this by yourself so they don't get loose and make a mess. Start the car and let the fluid drain. As soon the fluid stops coming out stop the car and refill to spec (3-4 qts i imagine). Repeat. When the fluid is clean..you're good. Be sure to fill to spec when you're done.
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
