3SFE Cam bearing torque - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2007, 10:47 PM   #1 (permalink)
View Montanahelp's Photo Gallery
I'm replacing the head on a 3sfe 4 cylinder. The repair manual calls for torqing the camshalf bearing caps to 14 ft pounds. My wrench doesn't go that low. 14 pounds seems awefully low. Can i torque them to 17 to 20 pounds?
Montanahelp is offline   Reply With Quote
Old 12-19-2007, 09:55 AM   #2 (permalink)
View Skiermang's Photo Gallery
You should be able to find a torque wrench that does inch/pounds and convert the measurements. Shouldn't be too expensive and will make sure you're right on the money.
Skiermang is offline   Reply With Quote
Old 12-21-2007, 11:54 PM   #3 (permalink)
Banned
View DressUpYourPet's Photo Gallery
You could possibly torque them to those settings and not hurt anything. But the parts under torque are probably cast aluminum, and so toyota probably set those torque settings so low for a reason.
Generally internal engine part torque settings assume clean bolt holes and lightly oiled bolts (one or two drops engine oil typically the assumed lubricant). I would think if you wanted to use loctite the settings about the same.
Still of course it would probably be better to torque them to toyota settings, harbor freight does have the inch pound torque wrenches that skiermang mentions and they are pretty cheap there. Hows $14.99 sound
http://search.harborfreight.com/cpisearch/web/attributeSearch.do?catPath=All%2BProducts%252F%252 F%252F%252FUserSearch%253Dtorque%2Bwrench&currentP age=2&lastPage=6&isNext=true&isPrevious=false&cate gory=&attributeValue=%2410+up+to+%2430&attributeNa me=Price+range&requestedPage=2
DressUpYourPet is offline   Reply With Quote
89 3SGE / 3SFE interghangable parts 89GTS Celica Forum 12 07-10-2006 09:24 AM
1MZ Cam marks won't align dgspencer Camry & Solara Lounge 5 03-15-2006 08:32 PM
Mystery Rolla wiccanferret Archived Corolla threads 20 04-07-2005 01:22 AM
Turbocharging a 3SFE Cam??? spills1969 Camry & Solara Lounge 9 01-18-2003 01:46 AM
How to apply 200 ft lb torque w/ 150 ft lb max torq wrench? Corbett Archived Corolla threads 11 09-26-2002 04:07 PM
