1989 Camry LE wiper fuse blown - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2007, 04:40 PM   #1 (permalink)
Matchbox Cars Collector
driline's Avatar
View driline's Photo Gallery
I've got a 1989 Camry that keeps blowing the wiper fuse. I'm going to check the motor and linkages tonight. I assume if the fuse blows that perhaps the linkages are siezed causing the fuse to blow? I hope this is a quick fix....
Anyone have this problem before?
driline is offline   Reply With Quote
Old 12-19-2007, 04:52 PM   #2 (permalink)
View CrashGraphics31's Photo Gallery
Its more then likely the motor. I would think if the linkages were locked up that the motors would get hot and burn up, but I could be wrong.
CrashGraphics31 is offline   Reply With Quote
Old 12-19-2007, 06:52 PM   #3 (permalink)
driline's Avatar
Ok, its not the motor. I ran a line from the battery to the wiper motor and it works fine in both slow and fast modes. However when I plug the wiper motor into the wiring harness it blows the fuse again.
2nd question...where is the wiper relay located? I've got a Haynes book but its practically worthless. Thanks again.....
Old 12-19-2007, 08:41 PM   #4 (permalink)
View toyomoho's Photo Gallery
Have you checked the motor parking switch used to stop the blade in the correct position, the switch is built into the motor. The wiper relay might be built into the wiper control switch inside the car. The washer pump is also on this fuse.
Old 12-19-2007, 09:14 PM   #5 (permalink)
driline's Avatar
Well then I guess I have no choice but to replace the wiper motor assembly if that is where the short is blowing the fuse. I'll talk to my Toyota dealership tomorrow and ask. They're pretty friendly. I've seen a used wiper motor on BadBay for $18.95.
Old 12-19-2007, 09:24 PM   #6 (permalink)
View fourdrinie's Photo Gallery
I believe on this car, the wiper relay is integrated into the wiper switch...check out the wiring diagrams
fourdrinie is offline   Reply With Quote
Old 12-19-2007, 10:54 PM   #7 (permalink)
driline's Avatar
USA
That won't be fun. Its in the steering column then?
Old 12-20-2007, 08:24 AM   #8 (permalink)
driline's Avatar
Lightbulb
I love all these FORD advertisments.
Like a Toyota owner would ever buy a FORD
1999 Camry power outlet and Cig outlet do not work? Fuse is not blown? leasure23 3rd & 4th Generation (1992–1996 & 1997–2001) 14 04-22-2012 02:11 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Which stock CD/tape players fit 1999 Camry LE? jbrams 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-11-2007 08:09 PM
2002 - 2005 Toyota Camry review! Lexusfreak 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-27-2006 03:43 AM
92-96 Camry LE V6 suspension- supposed to be firmer than 4-cylinder? 93 Camry LE V6 3rd & 4th Generation (1992–1996 & 1997–2001) 6 09-20-2003 02:33 PM
