Internal Distributor Oil Leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2007, 02:29 PM   #1 (permalink)
View fabbb's Photo Gallery
Found a good part source for oil leaks from the distributor shaft seal which results in oil inside the distributor. http://www.applied.com/ pn 10X20X7TC for around $6.00 per seal. It is a 10mm shaft dia/20mm outside dia/7mm deep/tc douple lip seal. The stock seal is 5mm deep but the 7mm unit goes in and works just fine.
SteveB
fabbb is offline   Reply With Quote
Old 12-25-2007, 07:14 PM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Just wandering, how were you able to knock out the distributor shaft to drive fork pin?
Doctor J is offline   Reply With Quote
Old 12-25-2007, 08:53 PM   #3 (permalink)
89 2wd's Avatar
View 89 2wd's Photo Gallery
I want to fix my distributor leak but...
'01 Tundra SR5 2UZ-FE 2WD
'89 X-tra cab 22RE 2WD
'91 SR5 4Runner 3VZE 4WD (sold)
'88 Camry LE 3SFE (sold)
89 2wd is offline   Reply With Quote
Old 12-26-2007, 08:22 AM   #4 (permalink)
Doctor J, I used a punch and hammer. I carefully blocked the distributor body up so just the drive dog set on the slightly open jaws of a vice. Be sure to mark the relationship between the drive dog and the shaft before you knock the pin out. Disasssembly of the distributor inards is pretty straight forward. Just be sure to observe the gaps between the pickups and the dist shaft triggers. I set mine at about .005" and it has worked on both of the distributors I have done this to.
89 2wd...no pictures for you!
Old 12-26-2007, 08:50 AM   #5 (permalink)
Doctor J's Avatar
Thanks, Fabbb
Old 12-29-2007, 02:53 AM   #6 (permalink)
89 2wd's Avatar
nuts, i just wanted to use that smiley
guess i wont be fixing my distributor on account that I dont really know what the hell you guys are talking about
Oil Pan / Leak bigblueyota89 89-95 Toyota Pickup/Hilux 8 03-25-2008 03:15 PM
Internal Distributor Oil Leak fabbb 3rd & 4th Generation (1992–1996 & 1997–2001) 0 12-25-2007 02:27 PM
Oil Leak when Accelerating??? renmike 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-08-2006 08:41 PM
Mysterious oil leak + wierd sound.. see pictures Mins Archived Corolla threads 5 01-20-2006 11:05 PM
I have a Rad fluid leak help me Loan Wolf Cam87 Camry & Solara Lounge 8 04-30-2005 02:19 PM
