Ported Vacuum Switch which one??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-03-2008, 02:13 AM   #1 (permalink)
Gameroom cash: $129205
View blu_91_cam's Photo Gallery
2nd Generation Ported Vacuum Switch which one???
I looked under the hood today and found that the rubber hoses that are connected to my ported vaccum switch had broken off since its been soo long and the plastic around the P.V.S had cracked off. I was just wondering if anybody knows which part number the P.V.S is for the 91 V6. not sure if its number 90925-05017 or 90925-05068. And does anyone know how important it is to have these fully connected? Cause their like 60 bucks a pop and I need to replace 2 of them. Thanks in advanced.
blu_91_cam is offline   Reply With Quote
Old 01-03-2008, 09:18 AM   #2 (permalink)
Doctor J's Avatar
Gameroom cash: $260390
View Doctor J's Photo Gallery
Is the vacuum switch blue or black?
Doctor J is offline   Reply With Quote
Old 01-03-2008, 11:43 PM   #3 (permalink)
actually its grey. Its the 2 closes to the front of the car. Thanks Doc
Old 01-04-2008, 08:53 AM   #4 (permalink)
Doctor J's Avatar
This valve is used to purge the charcoal canister. As coolant temp goes above 130degreees F the valve opens and the engine vacuum pulls the stored vapors from the canister.
You may use the normally closed blue colored valve (from the junk yard) from 81 to 87 Cressida or Supra (NOT FROM 87-90 CARBURATED TERCEL as it normally OPEN) It looks a little different but will work.
YOU CAN GET MORE INFO ABOUT THIS PART FROM www.ThePartsBin.com by using the first part number in part number search.
Prior to the installation make sure it opens when heated and stays closed when cold.
Old 01-05-2008, 12:29 AM   #5 (permalink)
Thanks alot for your help Doc. I dont realy have a salvage yard near by to pull parts from so I did a search and found that rockauto has them for 40 bucks a piece but theirs 3 different ones and 2 of them are by the same company but they all have different product numbers. Which one is the one for me?
Old 01-05-2008, 09:23 AM   #6 (permalink)
Doctor J's Avatar
Kragen.com has the cross reference chart for ported vacuum switches for the major aftermarket brands.
Old 01-08-2008, 03:39 PM   #7 (permalink)
Thanks alot for your help Doc you've been really helpful. I just received the switches in the mail from rockauto. Turns out their are 2 different valves.
Old 01-08-2008, 07:04 PM   #8 (permalink)
Doctor J's Avatar
Part No.
7792164
GP Sorensen Ported Vacuum Switch OE # 90925-05068The direct replacement from Kragen.com
Old 01-09-2008, 08:28 AM   #9 (permalink)
Doctor J's Avatar
ACDELCO Part # 212375 {#19110499}
VALVE,THERMAL VAC(ACDELCO) 90925-05068* Non-stock item--shipping delayed up to 12 business days *This one is from RockautoMore Info$49.79$0.00$49.
Compilation: Programming Remote entry for GEN4 camry keithy 3rd & 4th Generation (1992–1996 & 1997–2001) 36 09-05-2009 11:54 AM
expansion plug & fan switch Q dks 7th Generation (1993-1997) 1 11-12-2007 06:16 PM
Ignition switch replacement/starting problems Stringpickin 1st & 2nd Generation (1983–1986 & 1987-1991) 4 10-18-2007 12:14 AM
Hella 500 light switch ? Mike-in-WV 1st Generation (1995.5–2004) 3 12-28-2006 06:33 AM
Lighted Four Wheel Drive Switch Anyone? JUNGLEMAN 2nd Generation (2005+) 19 10-25-2006 08:07 AM
