Originally Posted by TBayToyotaBoy
Do you really have the precision equipment to set the alignment yourself?!
I was going to try the string method to improve things a bit. As far as I can tell, tire wear is not abnormal so it's not too bad, but it pulls a tiny bit to the right. The transmission fluid was pretty bad when I drained the pan:
I drained the pan, refilled, started the car and ran it through the gears, drained, refilled, through gears, etc.. a few times. I believe I put about two gallons through it this way. The last drain looked a little better:
Once spring rolls around I'll order a transmission filter kit and do the drain/refill/run dance again.
