To determine if the problem is electrical or mechanical , you need to attach the indicator light to the lock-up solenoid pigtail ( "back-probe" its connector with unfolded, sharpened paper clip, connect the clip to the small light bulb (12v, 0.04A) with long wire and ground another end of the light bulb). Tape the light to the windshield. When the comp. will command the TC to be applied, the light will be on. If during the RPM jump the light stays ON the problem is mechanical. If the light goes out at the rpm jump, the problem is electrical(could be as primitive as bad connector or Tp sensor/ brake switch input.
This test will not show thw intermitent electrical coil failure of the lock-up solenoid, so if the ellectrical test will be inconclusive you may try to put another good used lock-up solenoid.
