1985 Camry Park Lights Stay On
Hi guys!
I'm at my absolute wit's end with my little 1985 Camry. All of a sudden the car has decided that my park lights (including side markers front + back, and license plate lights) should never shut off. To me, that suggests a burnt out relay of some kind, so I set about pulling every relay I could find...but the lights refused to shut off.
For background, I believe that this car has had some electrical problems in the past, as evidenced by redone wires and electrical tape everywhere. This compounds my problem, of course, as it could be someone else
's F-up that led to this problem and I would never know. Unfortunately, I only bought it about a year and a half ago to replace my 1984 Camry that had just about rusted out from under me.
The only related problem I have had with the 85 is a drain problem, but that may well be related to bad battery. I replaced it early this winter, and the problem disappeared.
Any thoughts? I've been scouring every wiring diagram and taking every opportunity I can get to try to fix this for the past couple of weeks, but have had no success. All I could find was that all the lights are on the same, singular circuit (according to a Haynes manual), which makes perfect sense, but doesn't help me diagnose anything. I can always continue driving it and just disconnect the negative terminal any time that I park it, but that's awfully inconvenient...especially if I forget to do it at some point.
Please help, if you can. It would be very much appreciated.
Thanks!
