car pulling to sides - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2008, 06:36 PM   #1 (permalink)
View Lee250's Photo Gallery
When just cruising at a steady speed it ok but when you press the brake it pulls to one side, just a little though, and while accelerating it pulls to the other. Any thoughts?
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 01-07-2008, 08:30 PM   #2 (permalink)
View monito's Photo Gallery
2 thoughts come to my mind. Wheel misalignment and brake drag. If your wheels were misaligned, your car would pull one side during cruising.
My bets are on brake drag. Do you also feel pulsating while braking?
monito is offline   Reply With Quote
Old 01-08-2008, 12:57 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Most likely a bad front swaybar to control arm bushing. You can get replacement arms with bushings and ball joints on eBay for pretty cheap. Get both sides, replace the control arms and get an alignment.
-Charlie
Old 01-09-2008, 05:20 PM   #4 (permalink)
Yes that was another ? I had. When applying brakes and the car is still moving, like say above 20mph, the steering wheel shakes a little bit and the front makes enough noise to where it is noticeable but its not loud.
1999 Camry 2.2
Old 01-09-2008, 11:25 PM   #5 (permalink)
sounds like a brake job is needed. the vibration in the steering wheel is most likely caused by warped brake rotors caused by uneven wear. one way to check is to remove one wheel, and check the brake rotor for grooves.
BTW, if the noise you are hearing is metal to metal, you need new brake pads as of last week
Old 01-10-2008, 01:31 PM   #6 (permalink)
I checked the brakes yesterday and the pads were almost new. I'm going to try to get time today and take the calipers off and check the rotors.
1999 Camry 2.2
Old 01-11-2008, 12:05 AM   #7 (permalink)
you should be able to check for grooves without removing the calipers.
the side that's facing you is easy. for the inside rotor, just feel across the rotor from the center out. if you feel lines across the rotor, they should be ground for smoothness.
Chances are, you may just need to bleed the brake lines.
Old 01-11-2008, 12:58 PM   #8 (permalink)
I bled the brake lines and it seemed to help. I don't notice the steering wheel shake anymore and it dosen't seem to pull much either
1999 Camry 2.2
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
Questions on going Pro eddie926 Detailing & Car Care 7 10-17-2007 06:37 PM
New Car Questions TX WJ Camry & Solara Lounge 1 04-29-2006 07:54 AM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
why is my car keeps pulling to the right? Tubbyc Camry & Solara Lounge 21 05-10-2004 11:56 PM
