BEST START on Fix Older Camrys - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2008, 12:30 AM   #1 (permalink)
View rayboy7's Photo Gallery
USA BEST START on Fix Older Camrys
I have 1988 Camry Standard 4 cylinder. Have read many posts, and the Manual.
This is the BEST ADVICE you will get on older Camrys with Fuel Injection.
Before you do anything else. Clean all EFI (fuel Injection System) parts
except INJECTORs. (throttle body, sensors, valves, etc.)
Most important - REPLACE all rubber hoses (Vacuum, EFI, Emissions, Fuel)
Check Charcoal (vapor) Canister & replace if air won't go through it.
Now, check the timing. Mine had to be left at 15° BTDC (not 10° as recommended).
Now go on with most common problems checks (plugs, plug wires, distributor coil,
fuel filter, fuel pump, etc.)
Bad rubber vacuum hoses can cause the automatic timing adjust to be off, as well
as other things.
Hope this Helps EVERYONE,
rayboy7 God bless ya'll !
rayboy7 is offline   Reply With Quote
Old 01-09-2008, 02:33 PM   #2 (permalink)
View boi_si's Photo Gallery
why check filters. jus replace it.
-03 Matrix XR
-90 Celica turbo Alltrac
boi_si is offline   Reply With Quote
Old 01-12-2008, 05:14 PM   #3 (permalink)
AkinaSpeedStars
akinaspeedstars's Avatar
View akinaspeedstars's Photo Gallery
Thumbs up tnx rayboy
Hi,
Thanks for posting this advice. I'm not sure if it all applies to my 86, but I will certainly look into all these things. All my hoses are pretty good, not sure if I have a charcoal filter (where are they?), the engine is definitely starting to lag. It may just be the 230K miles, but I would like to have it back running clean the way it was about 50k ago. Thanks again.
-akinaspeedstars
akinaspeedstars is offline   Reply With Quote
Old 01-12-2008, 07:06 PM   #4 (permalink)
89 2wd's Avatar
View 89 2wd's Photo Gallery
My charcoal canister is just below the master cylinder, next to the fuel filter. My question is where would you expect to find a replacement?
'01 Tundra SR5 2UZ-FE 2WD
'89 X-tra cab 22RE 2WD
'91 SR5 4Runner 3VZE 4WD (sold)
'88 Camry LE 3SFE (sold)
89 2wd is offline   Reply With Quote
Old 01-12-2008, 08:35 PM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Would you believe the other day while I was at work (scrap yard) I picked-up an old (89) F150 with the loader to crush it and get it ready for shredding... when I had the truck pinched in the clam, I noticed something drop and roll from under the hood. I got down to pick it up, and it was a charcoal cannister. This thing was literally a tin can with two holes in the top--like Ford had taken an apple juice tin and filled it with charcoal for evap recovery. Even the corrugation on the sides of the cannister matched the juice tin type.
Talk about under-engineering...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 01-12-2008, 08:41 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
thats not a charcoal canister, its a vacuum chamber, we used to call it the pork n beans can
Old 01-13-2008, 01:08 AM   #7 (permalink)
89 2wd's Avatar
interesting, so what's its purpose?
will an upgrade to pineapple juice size help?
Old 01-15-2008, 01:12 PM   #8 (permalink)
Zod
View Zod's Photo Gallery
It acts as a vacuum reservoir.
Manifold vacuum varies with throttle opening, the can levels it out to an extent. The design has a check valve between the can and the manifold, with the accessories on the other side of the can.
If you've ever driven an older truck with vacuum wipers, you know what it's like with out one. Put your foot on the gas, and they stop.
Zod is offline   Reply With Quote
Old 06-29-2008, 05:06 PM   #9 (permalink)
You knew what this was.
disregard's Avatar
View disregard's Photo Gallery
do these "charcoal" canisters ever go bad ? The only thing that goes thru it is air right ?
1987 Toyota Camry LE 2.0 Sedan 200,000 miles.
1996 Nissan Maxima SE 3.0 Sedan 204,000 miles
maxima.org Nissan Infiniti
allpar.com Dodge Chrysler Plymouth Jeep
toyotanation.com Toyota Lexus Scion
disregard is offline   Reply With Quote
'85 rolla no start powerslide713 Older Generations (1969-1987) 10 04-08-2008 10:07 PM
buying 3 rare camrys? help! ! jecht Camry & Solara Lounge 18 09-30-2007 10:43 AM
Rust - to fix or not to fix.. Pics (56K friendly) islandboy57 3rd & 4th Generation (1992–1996 & 1997–2001) 20 07-20-2007 09:24 PM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
Click sound from under the hood..won't start snobdrblinkchik Camry & Solara Lounge 10 08-22-2004 09:04 PM
