1st & 2nd Generation (1983–1986 & 1987-1991)Toyota Camry Discussion for years: 1983-1986 & 1987-1991.
get rid of the doors.. that would save some major time... stock time is roughly 8 seconds i think
No way it is 8 seconds for a stock auto. Probably more like 10-13 seconds.
There isn't a whole lot you can do cheaply to make an auto faster. Advance the timing a bit (watch out for knock!), adjust the AFM a few clicks, high-flow muffler, remove some weight... After a few things like that, it gets expensive (turbos, motor swap, manual transmission swap, etc.).
-Charlie
Be honest with yourself: this car was designed by Toyota as an econo-daily driver. If you want a fast car, by a Celica or a Supra...or do what those with patience do: drop a 3S-GTE in!
__________________ 1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
Yeah its 12 sec. if you have some extra cash you can but new headers new intake new exhaust.....just small things i mean if your driving a camry im sure its because you cant afford something else (same as me) so your probably not going to be able to afford anything major. i guess you could change the pully kit too. and put a cellica head on it (if its the 1.8ci engine) just do some research and there is alot you can find
"There isn't a whole lot you can do cheaply to make an auto faster. Advance the timing a bit (watch out for knock!), adjust the AFM a few clicks"
-timing?
-what is "knock!"?
-AFM?
i'm interested so please do tell me about those mumbo jumbos.
nothing a little cant help with! But I will be nice...
timing: The relation of the spark plugs or valves to the location of the pistons.
Knock: is bad... The process of fuel igniting in the combustion chamber before it is supposed to (simplified).
AFM: air/fuel mixture
basically what everyone said above in relation to increasing power. The best you can do is to make what you have more efficient. You can decrease exhaust back-pressure, increase air flow (air filter cone mod), increase timing, and hack the computer to add more gas (richer mix). Thats really about all you can do short of turbo/supercharging, taking apart the heads and making the valves open more or increasing the compression ratio w/out blowing up the engine... but that gets expensive fast.
I don't like to be a wet blanket, but as mentioned earlier, the Camry is not designed to be quick. You would be much better off spending money towards a better platform and modifying that.
View my motorcycle trip writeups at motoblag.com.
Don't modify this car just drive it daily and buy a car to modify, thats what I did but backwards. I had the modifiable car first then this Camry after trying to drive my S2000 in the snow.
