oil pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2008, 12:53 AM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 oil pump
In the mornings when I start my car, or when it is completly cool and sitting awhile the oil light comes on and stays on for about 30 seconds. After about 30 seconds I can here the oil get sucked up and then the light goes out. I'm guessing it isn't picking up the oil for some reason. When I put and additive in like that lucas oil stabalizer it fixes the problem for about 2 days the it starts it again. Anybody have this happen before? I'm going to build the motor out of my parts car and swap them but that will be a while so I need this one to last a little longer. I don't want to change the oil pump on the motor in the car because that is alot of work and I drive this car everyday.
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 01-17-2008, 03:53 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I am tempted to suggest a better oil filter. There are several different types of one way valves (just a flap of plastic or rubber usually) that help to keep the oil in the filter so the engine doesn't have to refill it after being shut off (like right after you put a new filter on it takes 10-20 seconds for the oil light to go off while the filter fills up).
Russ Knize started a pretty thorough oil filter write up in 2003 though he still has a lot of filters to report on (I expect he has finished): http://minimopar.knizefamily.net/oilfilterstudy.html
Kep
Old 01-18-2008, 11:15 PM   #3 (permalink)
I'm running a Fram filter. I don't think it is the oil filter draining back because when I start it in the morning I can here the oil pump and after about 30 seconds I can actually here the oil all of a sudden get sucked up the pickup. I did get the problem fixed though. I changed my oil and I'm running 20w-50 with some of that Lucas oil stabilizer and the light only stays on for about 5 seconds now. Thanks for the help though.
1999 Camry 2.2
Old 01-19-2008, 07:38 PM   #4 (permalink)
View Kingdom934's Photo Gallery
20-50w? Wow...
I been using 10-40w syn for my Gen1. Change the oil filter every oil change.
What oil where you using before?
'85 Camry DLX 158K
'87 Cressida 78K
'07 Nissan Versa 63K SD (traded in)
'10 Nissan Versa 26K HB (traded in)
'04 Camry XLE V6 52
Kingdom934 is offline   Reply With Quote
Old 01-21-2008, 07:03 PM   #5 (permalink)
I was running the 10w-40 but then the oil pump wouldn't pick up the oil. Changing to the thicker oil solved this problem. I guess the previous owners didn't take care of it.
1999 Camry 2.2
Old 01-21-2008, 09:44 PM   #6 (permalink)
View toyomoho's Photo Gallery
The oil is drawn from the pan through a filter screen and oil inlet tube to the pump, and then is routed to the filter.
The oil inlet system to the pump could have an air leak causing the pump to have difficulty regaining its prime. Could be the drain back valve is stuck open in the oil filter try a different brand of oil filter such as Wix. The oil tube filter screen could be partially plugged restricting oil flow. The pump has a pressure relief valve, the valve might have a problem or the gears in the oil pump could have too large of clearance and not allow the pump to function normally. The oil pressure sensor could be bad, install a pressure gauge to test the engine.
Suspect the thicker oil is draining back slower, perhaps allowing the pump to gain prime faster.
Start with a different brand of filter, check oil pressure with a gauge, if bad check the oil pump (removable from the front of engine), oil pump screen tube (need to take off the oil pan) and oil pump check valve (located in the housing the oil pump bolt to).
First time oil change DIY = oil pump damage? ken_oy 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-15-2008 03:52 PM
Toyota Stand on Synthetic Oil siennavan General Discussion 51 12-09-2007 09:00 AM
Thick Oil in Camry Gen 5 cmathieu 5th & 6th Generation (2002-2006 & 2007-2011) 6 08-28-2007 01:49 PM
Low oil pressure after timing belt & oil pump seal change Hot66ss Camry & Solara Lounge 9 05-07-2006 08:44 AM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
