Vsv - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2008, 06:16 AM   #1 (permalink)
View mubienrulz's Photo Gallery
Vsv
hi,
i have a problem with my a/c the engine does not rev up when the a/c is switched on. so i replaced the vsv. i cant remember where the 2 hoses fixed. i got the mixed. btw the engine does not rev up after replacing it. any suggestions? and now i think its burning more fuel. i'm really stck with it. pls help
mubienrulz is offline   Reply With Quote
Old 01-16-2008, 10:43 AM   #2 (permalink)
argojos1's Avatar
View argojos1's Photo Gallery
I have a 90 Camry v6 and when i put the ac on it only goes up like 200 rpm's if that but my bro has a 91 corolla and his rpm's go up like a grand. I asked him about my car and he said there is nothing wrong thats just the way it is.
argojos1 is offline   Reply With Quote
Old 01-16-2008, 05:59 PM   #3 (permalink)
i tried connecting the 2 hoses, then the engine revs up. but still the vsv does not work when the a/c is turned on. is it the electronics? well its showing an error code 51 too. wat can i do?
Old 01-16-2008, 07:42 PM   #4 (permalink)
View toyomoho's Photo Gallery
Check to make sure the VSV is getting DC power to the solenoid.
Code 51 Switch Signals. 0roblem areas: A/C Switch/Circuit, A/C amplifier, TPS Circuit, neutral star switch circuit, ECU.
Old 01-16-2008, 07:57 PM   #5 (permalink)
there is a slight voltage coming about 1-3v. is that enough or should it be battery voltage?
Old 01-16-2008, 07:58 PM   #6 (permalink)
where can i fine the a/c amplifier?
Old 01-17-2008, 03:41 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
When the AC is turned on it sends an electrical charge to the VSV. The VSV then opens or closes the vacuum supply to the EGR system.
The 5SFE Engine section of the on line manual shows an inspection routine on EG1-224+ and has a general system diagram on EG1-390.
Kep
Old 01-17-2008, 08:12 PM   #8 (permalink)
my engine is a 3sfe. where can i find the routine check?
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
DIY : P0446 Charcoal canister VSV replacement Maim Menu 3rd & 4th Generation (1992–1996 & 1997–2001) 21 12-14-2010 04:27 PM
vsv question *PIC* simplyxtrippin Camry & Solara Lounge 3 07-14-2006 12:23 PM
VSV cleaning? brnyrd Camry & Solara Lounge 2 05-22-2006 05:24 PM
Wastegate or VSV problem? Mike@Fidanza MR2 Forum 2 05-09-2006 06:57 PM
