dome light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 07:52 PM   #1 (permalink)
View Lee250's Photo Gallery
Gen1 dome light
When a door is opened on my car the little light on the dash comes on that a door is open but the dome light won't come on and the switch on light is on door.
1986 Camry 2.0 Not going to let it die currently 228,000 miles.
1999 Camry 2.2
1986 tercel wagon 2wd - sold
Lee250 is offline   Reply With Quote
Old 01-21-2008, 08:06 PM   #2 (permalink)
Zod
View Zod's Photo Gallery
Check the bulb.
Obvious, I know, but excepting a fault in the wiring to the fixture, that would be the problem.
The door switch is working..
Zod is offline   Reply With Quote
Old 01-22-2008, 04:36 PM   #3 (permalink)
the bulb is ok. I took the hole assembly out and the plug for it slides on 2 metal pins and those metal pins are riveted to the contacts for the light and the rivets just fell off. I'm fixing that and then it should work.
1999 Camry 2.2
Old 01-23-2008, 10:10 PM   #4 (permalink)
View Dudeguesswhat's Photo Gallery
I had the same problem on my '86. I pulled the whole thing out and made sure all the contact points were clean and, well, making contact. Works fine now.
It's kind of a goofy setup, as you mentioned the 2 pins just kind of slide out, so make sure you get it back in there right.
Dudeguesswhat is offline   Reply With Quote
Dome light michoujordan76 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-24-2012 02:18 AM
Dome Light Bulb Choice? thapranksta 5th & 6th Generation (2002-2006 & 2007-2011) 28 01-13-2008 11:05 PM
How many forum members does it takes to change a light bulb? hiace24 Off Topic 14 01-10-2008 09:19 PM
Dome light with key removal? tonyreo Camry & Solara Lounge 9 02-17-2006 09:01 PM
'90 Camry, should dome light burn when REAR doors are open? CHaynes112 1st & 2nd Generation (1983–1986 & 1987-1991) 4 02-06-2005 04:01 PM
