Chirp noise when starting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2008, 11:25 AM   #1 (permalink)
View jefe's Photo Gallery
2nd Generation Chirp noise when starting
Is it the starter? I noticed it being much worse in the very cold weather. It's kind of a chirp/vibration type sound right when the car starts. When it happens in warm weather it only last for a split second immediately after starting. In extremely cold weather there is a 1-2 second pause, then the noise for a longer period (maybe 1.5 seconds) then it stops.
91 3sfe automatic. 260K miles. Original starter.
I thought it might be the starter, but I found this thread and it seems like it happened some after he replaced the starter.
90 Camry Wierd Starting Noise
Thanks, Jefe
jefe is offline   Reply With Quote
Old 01-22-2008, 12:17 PM   #2 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Check your drive belt tension. It may be loose.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline   Reply With Quote
Old 01-22-2008, 12:23 PM   #3 (permalink)
I will, but it didn't sound like the more continuous whining I got when my alternator belt was going a few years back.
Old 01-23-2008, 05:41 PM   #4 (permalink)
View marc780's Photo Gallery
Without seeing or even hearing the car here are some wild guesses:
1 - starter installed wrong, dirt or a washer or an object lodged between starter and bellhousing, making starter misaligned
2 - worn out, broken or missing teeth on flywheel
3 - abnormal starter solenoid or starter noise - it might be worth a try to put in a junkyard ditto to see if the noise goes away
4 - timing belt idler running dry?
5 -water pump noise (not likely because it would probably make noise all the time)
Old 01-23-2008, 06:52 PM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
I get this sound in all three of my Camrys (two I4s and a V6). It only happens for me in extremely cold weather (like, as in -13 degrees Farenheit). It's been very hard to isolate, as I cannot convince my beautiful assistant/fiancée to help.
As near as I can tell, it's the alternator bearing complaining in the cold. Even with the block heaters plugged-in, and the block nice and toasty, I still get the sound.
It's possible on your camry that it's another bearing making the sound, though. How cold has it been where you live, lately?
Edit: Sorry, just saw that you're in MN, not far from here (and just as cold). I'm guessing worn and cold bearing.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 01-24-2008, 04:37 PM   #6 (permalink)
Mad Scientist-In-Training
toyrolla's Avatar
View toyrolla's Photo Gallery
Wink
It happens to me every morning and evening.
I changed my belt while doing maintenance at the end of summer (right after Labor Day weekend), and after a few weeks I noticed the noise upon start and as I drove away.
When it grew to be more frequent, I checked under the hood and found that it was coming from the belt.
I thought I had tightened it, but I guess it wasn't tight enough so I did that and it went away.
Well, since the winter, especially during very cold mornings (I fire it up every morning around 5:30am), you can hear it go "screeeech" then it goes away.
The difference between the loose belt scenario and the cold weather scenario is that it "screeched" longer when the belt was loose. When it's cold, it only happens when starting up.
Hope this helps...
Regards,
Toyrolla
__________________________________
88 I4 Slushie *sold*, 89 I4 5Sp *sold*, 89 V6 5Sp *sold*, 82 Corolla, 72 Datsun 510, 88 Toyota Minitruck.
toyrolla is offline   Reply With Quote
Old 01-24-2008, 05:54 PM   #7 (permalink)
Bullitprooph
Maybe you'd better post a vid with good audio so we can hear this sound...
Old 01-25-2008, 01:38 PM   #8 (permalink)
I thought I remembered an old thread (that I can't find) talking about this. I thought the starter engages the flywheel and then should retract away from it and when the starters on Gen 2's age they don't retract as quickly and as the more slowly move that causes the noise. If left for a long time it eventually causes the flywheel teeth to wear down...
Old 01-25-2008, 05:29 PM   #9 (permalink)
Gameroom cash: $302555
New belts will stretch a bit after a few hundred miles of driving. This is especially true of aftermarket belts. The smaller diameter power steering belt seems to stretch a bit more, but both belts can stretch after some initial usage.
Mike
Mike Gerber is online now   Reply With Quote
Old 01-28-2008, 02:11 PM   #10 (permalink)
argojos1's Avatar
View argojos1's Photo Gallery
It happens on my 90 camry v6 only when it cold out.
argojos1 is offline   Reply With Quote
Strange rattle in a 1997 on starting mankind117 7th Generation (1993-1997) 1 11-08-2011 06:14 AM
Should I Skip The Camry Alltogether?!?! hikix 5th & 6th Generation (2002-2006 & 2007-2011) 104 05-29-2008 11:33 PM
engine makes a whistle noise when starting up on cold mornings rampge1 2nd Generation (2005+) 1 01-15-2008 12:27 AM
Rattling noise when starting Japcam Archived Corolla threads 0 08-17-2005 12:11 AM
Problem with noise at 2100 rpm Cyberdave Camry & Solara Lounge 2 06-29-2005 11:10 AM
