more
I have a california model with a sensor off each bank. Then again I haven't seen my car in year so maybe it only has one???? Get a mulitmeter on it set to VDC. Back probe the sensor to take the reading. While the car is running (and already warmed up), it should actually make a voltage from 0V-1V. Nomial is .5V. It should cycle every couple of seconds at idle, and even faster at higher RPM's. If I remember right,....Rich is 0V and lean is 1V. The material in the O2 sensor creates a voltage when it reacts to extra Oxygen. Oh, you'll probably need to have the car on ramps or jack stands to do this.
Good luck
90' ES two-fity, balanced motor, head work, home built intake, lowered, wheels, window tint and some stereo upgrades, next...building my headers.
