Inner Tie Rod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2008, 03:00 AM   #1 (permalink)
View rdalton33's Photo Gallery
Inner Tie Rod
So I need to replace my inner tie rod, I rented the tool to do the job and plan on tackling this myself as it looks pretty straight forward. Is there anything I need to look out for from anyone else's previous experience in changing this part?
rdalton33 is offline   Reply With Quote
Old 01-23-2008, 02:17 PM   #2 (permalink)
Gameroom cash: $129205
View blu_91_cam's Photo Gallery
Hey I wanted to try the very samething. If you dont mind take a bunch of pictures and do a write up on it Thanks man
blu_91_cam is offline   Reply With Quote
Old 01-23-2008, 05:32 PM   #3 (permalink)
View marc780's Photo Gallery
Carefully measure the old one before you remove it. Measure the tie rods center-to-center and record this figure.
Loosen the lock nut and CAREFULLY COUNT the number of complete turns it takes to get the old one off. Now compare the old tie rod to the new. they should about exactly the same length.
Now spin the new one on the same exact number of turns it took to get the old one off. Bang the ball and shaft into place in its hole and tighten the nut firmly but not to final yet...first measure your center-to-center again - the measurement ought to exactly match the figure you wrote down. (If all goes well you might be able to avoid paying for a wheel alignment).
If everything looks good, tighten the castle nut and insert a new cotter pin and bend it, and you are done. Keep an eye on your front tire wear for a few weeks. If the tires are wearing irregularly i'd consider changing the rest of the worn out front end parts too before getting a wheel alignment.
Old 01-23-2008, 11:23 PM   #4 (permalink)
Toyota Tom
View T.M.Hews's Photo Gallery
What promped you to do this? I have been experiencing a dull thud when i hit a bump noise is coming from right front end. Think it might be a strut but don't know.
Can you advise me on this?
T.M.Hews is offline   Reply With Quote
Old 01-24-2008, 06:14 PM   #5 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
You're going to have to do some specific diagnosis on the front end of your car. There are so many things that can cause front-end noise. Inner tie-rod end, outer tie-rod, balljoint, rotten/worn control arm bushings, pooched struts.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Inner Tie Rod Replacment with Pics. Oinktron Hardcore Tech and Competition 2 01-11-2008 02:36 PM
Inner Tie Rod Replacement 91boz Older Generations (1969-1987) 4 09-21-2007 02:50 PM
Tie rod question JohnSWA Archived Corolla threads 6 07-04-2007 10:08 PM
tie rod Q+A Redlyne_mr2 Hardcore Tech and Competition 5 01-12-2006 12:13 AM
Inner tie rod SW21 MR2 Forum 5 11-07-2005 04:30 PM
