codes?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2008, 03:26 PM   #1 (permalink)
View jimcls1's Photo Gallery
codes??
hi, i am new here and have a question. i have a 90 camry and got 3 codes 24 31 and 41 code 31 is Air Flow Meter signal (Vacuum Sensor signal i don't see any vacuum line going to this? what is this?
jimcls1 is offline   Reply With Quote
Old 01-28-2008, 02:59 PM   #2 (permalink)
anyone
Old 01-29-2008, 12:49 AM   #3 (permalink)
Pochacco Owns Me
atobe's Avatar
Gameroom cash: $406595
View atobe's Photo Gallery
lets see
24 = intake air temp sensor signal... open or short circuit in intake air temp sensor
31 = air flow meter
41 = throttle position sensor
how did you go from air flow meter to vacuum ? it only tells how much air flow there is it doesn't measure the vacuum of the engine like a MAP sensor... sounds like your MAF is broken or got a short.
Old 01-29-2008, 03:27 PM   #4 (permalink)
Air Flow Meter signal (Vacuum Sensor signal). this is exactly what it said online. it doesnt make sense okay so now i have a bad maf?
Old 01-29-2008, 05:07 PM   #5 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
You will need to verify the operation of the AFM. Make sure the plug is tightly plugged in, and that the screws that hold the connector to the AFM are not removed. The wiring harness can be disconnected by removing the small metal clip around it - do not mess with the screws.
-Charlie
Old 01-29-2008, 05:21 PM   #6 (permalink)
how do i check this??
Old 01-29-2008, 05:48 PM   #7 (permalink)
View toyomoho's Photo Gallery
Suggest picking up a manual. The Haynes 1983-91 Camry manual (number 1023 ) covers testing all of these components, cost under $20. You will need a volt/ohm meter.
Guessing given the location of these sensor you might have a wiring issue.
"Check engine light" error codes po446, po442, po440???? serabell xA Forum 10 04-12-2009 10:31 PM
Prius Codes, no start crxdan Prius Forum 4 02-10-2007 03:40 AM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
Reading codes White89SR5 Archived Corolla threads 3 03-12-2006 08:22 AM
Rading ABS Codes from 95 Toyota Camry satexascamry 3rd & 4th Generation (1992–1996 & 1997–2001) 12 04-09-2005 10:05 PM
