temperature drop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2008, 12:36 PM   #1 (permalink)
View ladyofluck's Photo Gallery
temperature drop
starting few years ago, my car started to drop it's engine temperature quite rapidly. so when i go down hill w/o using the gas pedal, the temperature actually goes back down to cold....
so what could be wrong w/ it? car seems to run fine, but just temperature rises slower than b4, and decreases quicker than b4.
ladyofluck is offline   Reply With Quote
Old 01-29-2008, 01:06 PM   #2 (permalink)
View nuron's Photo Gallery
It's probably a thermostat that is open a lot instead of being variable to increase or decrease the flow of coolant like it's supposed too. Better open than closed all the time like mines was!
nuron is offline   Reply With Quote
Old 01-29-2008, 01:18 PM   #3 (permalink)
3s-gte in a Camry?!?
white90dx's Avatar
Gameroom cash: $305775
Ummm... you let it go *years* like that??
Just replace your thermostat. Quite a simple fix. Get an OEM Toyota one if it is in your budget. Consider replacing your radiator and heater core hoses along with your radiator cap while you you are in there.
-Charlie
Old 01-29-2008, 02:56 PM   #4 (permalink)
Gameroom cash: $302555
I have to agree. You have the classic symptoms of a thermostat that is stuck in the open position. Change the thermostat and it's gasket and properly bleed the cooling system. Your heat will be hotter and your gas mileage will also improve a bit.
Mike
Mike Gerber is online now   Reply With Quote
Old 01-29-2008, 04:42 PM   #5 (permalink)
okay.. so is it simple enough for me to just swap it?
or do i have to take it to mechanic?
if it's easy, can anybody tell me where about i can find this thermostat? thx
Old 01-29-2008, 04:53 PM   #6 (permalink)
white90dx's Avatar
Replacing the thermostat is one of the easiest repairs you can do on the 4-cylinder Camry. You will still need a few different sockets to get to it.
The thermostat is on the water inlet of the motor, under the alternator. A Haynes or Chilton's manual can walk you through it pretty easily.
-Charlie
Old 01-29-2008, 04:57 PM   #7 (permalink)
View toyomoho's Photo Gallery
Easy enough. Follow the lower radiator hose back to the engine. The T-stat is located under the housing the hose attaches to.
The coolant needs to be drained; there should be a drain valve on the radiator. The housing is held on by a couple of nuts. Make sure to install the new T-stat with the large spring facing the engine and the small hole in the T-stat outer housing oriented in the up position. Use a new rubber gasket around the T-stat (if it doesn’t come in the box).
Old 01-31-2008, 01:22 PM   #8 (permalink)
i must drain? where would i go about and dump it?
Old 01-31-2008, 03:11 PM   #9 (permalink)
Zod
View Zod's Photo Gallery
I'd suggest draining it into clean containers, and reusing the coolant.
Unless it's up on a change.
No disposal required, and you won't need to buy antifreeze..
Zod is offline   Reply With Quote
