88 SV21 front end noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2008, 10:48 PM   #1 (permalink)
KamryKruizer's Avatar
View KamryKruizer's Photo Gallery
hi peeps
my camry had its passengers side CV shaft replaced about 2 months ago. the strut was also replaced as was the lower ball joint. after a while the car has started to get a low notchy vibration coming from front end somewhere.
if you would imagine a flat spotted tyre, thats what it sorta feels/sounds like but im getting no huge vibrations, more a low grumblin growly notchy feel, the faster i go so does it. so its something rotating.
theres no vibration thru wheel or brake pedal, its coming from the front somewhere.
seeing as ive already replaced cv/ball joint/strut on this side do you think it might be the hub bearing on this side? has anyone else had a similar experience?
thanks in advance for your replies
KK
KamryKruizer is offline   Reply With Quote
Old 02-16-2008, 09:13 PM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
If it's the hub that's going/gone, you will likely get some "pull" in the steering wheel to one side or the other (passenger side=pull to the right, usually).
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-16-2008, 10:19 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
save yourself some grief and do both sides
Old 09-08-2008, 07:19 AM   #4 (permalink)
boy were you right 3 months later the other side goes but i spent $$$ chasing the noise, shouldve listened to you
