88 camry 3fse oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-21-2008, 07:29 PM   #1 (permalink)
View leatherneck270's Photo Gallery
USA 88 camry 3fse oil leak
I have an 88 3fse, 4cyl, auto with 189,000K miles. she runs well with a couple of issues. First is a bad oil leak from the front drivers side of the engine at the head block mating area. No oil and water mix.. So I am going to replace Head gasket,timiing belt,oil pump,water pump. I did a compression test and all cylinders came up to 185-187psi. So does anyone think while to perform the above, should I change the rings and bearings also?..
anyone else have the oil leak issue....
she also has a vibration when idling in gear and sitting still only.. Idea's???
leatherneck270 is offline   Reply With Quote
Old 02-21-2008, 11:09 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
With that mileage you better pull the pan and push em out and do rings, bearings, all the seals on the front, the distributor seal from kbox.ca and just make a day of it, it is a easy car to work on and the cams will have to come out to get the head bolts out, notice that you will have to put a little bolt in the one cam gear that has the backlash spring gear on it to hold the spring, The block will be ok, just scuff the walls a little and new pistons will go along ways to a quiet motor since the 3s is known for piston slap and get good ones, pull the head with the intake on it
Old 02-22-2008, 01:36 AM   #3 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Why do you recommend pulling the head with the intake still attached? Wouldn't this be a convenient time to replace the intake gasket before it gets brittle and starts leaking? You are far more experienced with the 3SFE than I am, so I'm curious...
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 02-22-2008, 09:46 AM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
its alot easier to get the intake off the head when its off the motor
Old 02-22-2008, 10:32 AM   #5 (permalink)
View Fruitbat's Photo Gallery
Wow, you're going pretty hardcore on that old Camry. Mine was leaking/burning about 1L/1000 miles for the past....forever. I figured it was cheaper and easier to just keep topping it off. Then again, I wasn't planning on driving it forever.
Timing belts on S series engines = nightmare, in case you didn't know.
The vibration sounds like engine or tranny mounts. Since you'll have to take a couple out to do the timing belt, you might want to look at replacing them at the same time.
Old and Busted: '84 Camry LE <2S-E> || '89 Celica GT-S <3S-GE> || '91 Camry LE <3S-FE> || '95 Camry LE V6 <1MZ-FE>
New Hotness: '08 Matrix XR <1ZZ-FE>
Fruitbat is offline   Reply With Quote
Old 02-22-2008, 06:01 PM   #6 (permalink)
Fredk
Thank you for the info, wasnt sure if I should replace rings and bearings since the compressor was excellent. But you make since, because i am there anyway. Piston replacement?? really, I did not think that was required. It an old car, but we have a new jeep and I only use it to go to and from work,,and it still gets 30 plus mpg.... and I dont need another car note. thanks, i will price out pistons also
Thanks
