oil leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-27-2008, 06:38 PM   #1 (permalink)
mcx
View mcx's Photo Gallery
oil leak
i was motivated today to do alittle worlk on the 91 with a 2.0/auto...it has a steady drip oil leak when its running[wasting alot of oil]...i changed out the valve cover gasket because i would of sworn that was where it was leaking[rear of engine all the way down is a Valdez disaster...wrong guess...i jacked it up,took off the pass side wheel and inspection cover...i guess its either the oil pump or crank seal because its a steady drip drip drip from that lower rear edge??? the repair manual says the engine mount has to be removed to do the timing belt..is that true in all cases??does the oil pump on the 2.0 have a seal??
mcx is online now   Reply With Quote
Old 02-27-2008, 08:03 PM   #2 (permalink)
View toyomoho's Photo Gallery
It appears the mount needs to be removed to access the upper timing belt cover. The oil pump does have a seal on the drive shaft also pickup the O-ring seal that goes between the oil pump and pump case.
Make sure the pump gears are aligned with the dot facing each other.
Old 02-27-2008, 09:45 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
its the oil pump, get the plaStic belt cover off, put the crank pul;ley back on and get it all cleaned up with brake clean, get it running and see if its the pump cover or the pump itsaelf where it bolts to the iron block
Old 02-27-2008, 10:00 PM   #4 (permalink)
mcx
...very nice idea....thx,mike
Old 02-27-2008, 10:32 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
look at all the seals behind the gears the timing belt turns too, is the oil all over the timing belt?
