I've wired a few Camrys for trailers.
First it's not necessary to wire it in before or after the light failure sensor. If you use trailers that use the 4 prong plug that has Ground, Tail, Right stop/turn and Left stop/turn Reese makes a module that converts the separate turn and brake lines to combined lines.
A wiring "dongle" can be made from a donor Camry by cutting out the harness plugs that are used in the trunk of a wrecking yard Camry. That way you don't run the risk of permanent damage to the harness of your car. The end result is also cleaner and more professional.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
