Originally Posted by stumeston
Where is the fuel filter located on a '90 Camry LE with the stock 3S-FE engine and how would I go about changing it?
It's the cylindrical black thingy there. You can get a socket on the top, then use a wrench on the filter body (17 or 19 mm). Pull then against each other, loosening the top banjo fitting. There will be two copper crush washers: one between the banjo bolt and one between the fuel line and the filter body.
To get the bottom off, find out which wrench fits the hard line underneath. I think it's a 12mm or so. Once you get an open ended wrench on it, go to the parts store and get a flare nut wrench. You will get more of the bolt and it makes it much hard to round the nut. Once you have the flare wrench, put the open end wrench on the filter body and pull the wrenches together to loosen the fitting. I don't recall if there is a copper washer on the bottom but I do not believe so.
