Power Steering Pump - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2008, 08:18 PM   #1 (permalink)
View Cpt Marvel's Photo Gallery
Power Steering Pump
Heya; 90 Camry w/2z 2.5l Auto. Where in the world are the bolts to loosen to get the power steering belt off? I find one bracket on the side behind the wheel, has a slot. Obviously this is one but after loosening the two bolts it still don't move. Can't readily see the other.
Question 2; I have visited another Camry forum but can't find it now. Anyone know of others?
Cpt Marvel is offline   Reply With Quote
Old 03-13-2008, 11:13 AM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
It looks like the pivot bolt (through bolt) is behind the pressure hose fitting and the adjusting bolt is on the bottom in that slot that you found. There doesn't seem to be a separate set of instructions for the I-4 vs V-6 so this should be correct.
Kep
(MAIN POINTS OF REMOVAL AND INSTALLATION OF SV25 (and SV21?) SERIES POWER STEERING PUMPS)
1. DISCONNECT AND CONNECT PRESSURE LINE
Disconnect and connect the pressure line (may need a special tool).
HINT: When connecting, use a torque wrench with a fulcrum
length of 340 mm (13.39 in.).
3. REMOVE DRIVE BELT
(a) Loosen the adjusting bolt and the through bolt and
push the PS pump forward.
(b) Remove the drive belt.
2. DISCONNECT TIE ROD END RH
(a) Remove the cotter pin and nut.
(b) Disconnect the tie rod end RH. (may need a special tool)
4. REMOVE PUMP BRACKET
(a) Remove the adjusting bolt.
(b) Remove the bolt and bracket.
5. REMOVE REAR PUMP STAY
Remove the two bolts and stay.
6. REMOVE PS PUMP WITH PRESSURE TUBE
(a) Remove the through bolt.
(b) Remove the PS pump from the lower side of body.
Old 03-13-2008, 06:21 PM   #3 (permalink)
Thanks. Seems the only thing easy to do on this car is wiper blades.
Old 03-14-2008, 12:58 PM   #4 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
That's what we get for having small (midsize) cars with transverse V6 set-ups. Giant PITA.
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 10-06-2010, 07:05 PM   #5 (permalink)
View Tanuis's Photo Gallery
Dose any one have any pictures of this process..
while i have done some work on cars this would be my first time actualy try to install a new Pump i kinda want to know what i am looking at first.
Tanuis is offline   Reply With Quote
Old 10-06-2010, 10:46 PM   #6 (permalink)
View Tatohead's Photo Gallery
Holy cow. I just replaced the PSP in my 90 Camry today. However, I have a 4-cyl. It was extremely difficult, but sounds like a walk in the park compared to the V6.
Good luck!
Tatohead is offline   Reply With Quote
