Originally Posted by speed_camry30
Couldn't I cut-out a section of the scap metal and use fiberglass? I don't have acces to a welder or buy one?
Call the local welder dealerships like airgas or lincoln and alot of them rent em out. Just get a Mig w/ nitrogen or co2 bottle for a day. You will then drill holes in the remaining metal on the car. Take your repair patch and fit it. You will want to flare the outer edges of the new material to make up for the thickness (less bondo) so that it's at the same or a bit less on the height.
Then when you back up the new material to the actual holes in the existing vehicle, fill the holes with the mig welder and grind smooth. Then bondo, sand, prime.
