Tail Lights out!!? -Bulbs are Fine- '91 V6 LE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-18-2008, 07:27 PM   #1 (permalink)
View toyotown's Photo Gallery
I was pulled over last night for not having tail lights, but they let me off with a warning.
This morning I tested the bulbs; they're fine.
Are the tail light fuses located under the dash with the others? I don't have the fuse diagram, so I'm lost.
toyotown is offline   Reply With Quote
Old 03-19-2008, 02:46 AM   #2 (permalink)
Bullitprooph
TBayToyotaBoy's Avatar
View TBayToyotaBoy's Photo Gallery
Look under the cover of the fuse block (check the one at your feet first, then the one under the hood if need be), there's a diagram on there showing which fuses are which...
So am I getting this right, that the cop claimed you had NO tail lights at all? And that you tried them today and they worked? Or do you mean that they're all off but that the bulbs are good? How about reverse lights? Turn signal lights?
1990 5spd V6 Camry (Still kicking at 393,000km) 1991 Celica GTS -- Pappa needs a 3SGTE...and AWD for all this friggin' snow
Honda my A$$, you just can't kill a Yota...
TBayToyotaBoy is offline   Reply With Quote
Old 03-19-2008, 05:26 PM   #3 (permalink)
Gameroom cash: $302555
If your fuses check out to be OK, then I would next check the loom of wires inside the trunk, by the driver's side trunk hinge. The wires inside there have a tendancy to frey and break from all the flexing they are exposed to when the trunk is constanty opened and closed. Open up that loom and look for freyed or broken wires. Repair as necessary.
Mike
Old 03-20-2008, 01:18 AM   #4 (permalink)
I meant that I'm getting NO tail light, but the bulbs are still good. I checked the underdash fuse and it tests okay, too.
I'll check out the trunk loom tomorrow and let you know how that goes. I'm guessing this is a common problem?
Old 03-20-2008, 03:43 AM   #5 (permalink)
1LovE
View 1love's Photo Gallery
i got pulled over n let loose to..by an undercover..?! i checked the bulbs, all fine. when i swithed the left n tight housin cases all was okay
i have no idea what to do the left brake light goes off only when the car lights are on, if it were day, then brakes work perfect can any one help me out??
thanks
1love is offline   Reply With Quote
Old 03-20-2008, 05:50 PM   #6 (permalink)
View marc780's Photo Gallery
Im not sure exactly what you are talking about 1love, housing of what?
thanks
The brake light bulb is probably a dual filament, either one filament is blown on that bulb, or you need a new stalk switch? also check the fuses too.
Old 03-20-2008, 05:54 PM   #7 (permalink)
jlspec's Avatar
View jlspec's Photo Gallery
Make it easy and just get new bulbs and try it. The bulbs are like what $3 at walmart? If that still doesn't work then check your fuse. If that's OK then check your wires.
1990 Celica Turbo All-Trac
jlspec is offline   Reply With Quote
Old 03-21-2008, 12:15 AM   #8 (permalink)
The bulbs, underdash fuse, and trunk wire loom are all in good shape. I guess there might be a short somewhere else in the wiring...
Old 03-22-2008, 03:06 AM   #9 (permalink)
1LovE
so this morning i got curious anf fiddled witht the radio and cigarette plug, i also wrapped elictrical tape around the clutter of wires. Apparently the brakes seem function correctly.
Should i leave this alone since all is fine?
Old 03-25-2008, 10:32 AM   #10 (permalink)
Not so Noob now!
es250nut's Avatar
View es250nut's Photo Gallery
I've seen this before.
I suspect your taillight sensor module has been cooked. Caused by putting a single filament bulb in a dual filament slot. Check all your bulbs to verify they are correct for the slots then check the module (yellow box) which is next to the fuel filler under the left rear quarter panel.
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
es250nut is offline   Reply With Quote
Old 03-25-2008, 10:16 PM   #11 (permalink)
1LovE
Thanks, ima chrck up on it once sunrises
